Knowledge request - Petter M type 4HP Mixture screw
Post by StewartH on Thu Aug 08 2013, 10:50
Hello Ladies and Gents,
This is an appeal to those of you with specific Petter M type expertise and knowledge.
I'm looking at an opportunity to buy an M type for restoration (it’s the exhaust sound and smoke rings I like!) however the owner says, amongst many other issues, that the mixture screw is missing - my question is...
Is this mixture screw transferable from all HP ranges on M types - so for example could I find a 5HP M type carb with mixture screw and disassemble it to use it on the 4 HP?
Any guidance will be much appreciated - and paid off in pints of ale at some show!
Best
Hamish
StewartH
Re: Knowledge request - Petter M type 4HP Mixture screw
Post by Villiers on Thu Aug 08 2013, 11:32
As far as I know the mixture screw is the same on all M types, your best be with questions like this would be to speak to Roland Craven on the IF forum, his web page is closed down at the moment, I think someone has been cut n paste stuff off there and he has gotten the hump a bit.
Post by StewartH on Thu Aug 08 2013, 12:43
Thanks a million Villers - much appreciated. I was wondering why the Petternut website was down - I'll track Roland down as he's gonna ba a close friend very soon if i get this M type!. Best Hamish
StewartH
Post by Villiers on Thu Aug 08 2013, 13:01
Apart from the screw what else is missing? 4hp engines are not common, 3 and 5 are, if I remember right (Don't quote me though) I think the 4 is a down rated 5 anyway.
Post by StewartH on Thu Aug 08 2013, 14:36
Thats interesting to say its a downrated 5HP - which gets me thinking if items like crank and pistons are the same....aparently there is the atomiser missing but these can be found on ebay - the skew cut gears for the magneto are missing/ broken - but I might have a friend with a broken BTH that might fit.....
the bigger issue will be the 1/4" Phosphor-bronze ball under the vaporiser - it might need an endmill to recut the seat top and bottom - but as my shed is about 1m square and currently has lots of my kids toys in it I will be outsourcing this to my local engineering firm - whoever that may be.. probably in China by now....
I'll have to make a desicion pretty soon but it seems like a resaonable enough project! - just a load of rusty parts right now! best, Hamish
StewartH
Post by Villiers on Thu Aug 08 2013, 15:20
I have a mag gear for a 3/5 M,
Post by StewartH on Thu Aug 08 2013, 16:39
You may just be a saviour..... I have also just signed up for the IF forum - and see they have a huge Petter archive - great info - must be most of Rolands knowledge right there! - and definately a place i will spend some time reading before making my first steps into restoration of an M type! Ta for the pointer - ale awaits at the next show!
StewartH
Post by fowlerfan on Thu Aug 08 2013, 21:00
I am fairly sure 4 HP engines are actually uprated 3 HP engines (apologies if that adds confusion!).
Years ago I had a scrap 4 HP engine that was a real rot box, I needed a flywheel and the exhaust pot for a 3 HP engine I was restoring, and these parts were a direct swap.  The rest of the engine was either missing or badly corroded and eventually scrapped.
The only 4 HP reference I have found on the web is an engine sold at Cheffins, it is definitely a 3 HP size but probably uprated speed to 4 HP.  (assuming of course they have read the plate correctly!)  http://www.cheffins.co.uk/lot/-526767-vintage-0
Carbs come up for sale fairly often so a mixture screw should be easy enough to find.
Cheer Dave
fowlerfan
http://www.stationaryenginesscotland.co.uk
Post by Villiers on Thu Aug 08 2013, 21:27
Now you mention it Dave you could be right! There is a carb on ebay at the moment for a 5 so that might be good for a mixture screw.
Post by StewartH on Fri Aug 09 2013, 09:20
Hi Villiers - Just sent you a PM asking a daft question on the ebay carb.
Dave - many thanks for this info - it all helps me build the picture of what to expect and how to support the project in terms of hunting down those elusive parts!
Hamish
StewartH
Post by fowlerfan on Fri Aug 09 2013, 16:08
Parts for 3 HP and 5 HP M's are fairly easy to come by so I wouldn't be too worried if a few small parts are missing, the sought after parts are the mags, gears and exhaust pots. These do turn up but attract a premium.... As with any M type I try to recommend buying the best engine you can afford.
Cheers Dave
fowlerfan
Post by StewartH on Sat Aug 10 2013, 21:08
Cheers Dave - and it's for that very reason I declined both my friends m type and decided not to bid on the eBay 4hp restoration project as well - good projects for those with a better equipped workshop but too much for a newbie!
The search continues................
StewartH
