fuel tanks
fuel tanks
Post by Dafydd Tai Hirion on Wed Aug 21 2013, 19:54
Hi, I have a bamford open crank engine 5/6 bhp. and I an restoring her. there is three tanks on the engine. The petrol and paraffin I know about. but what is the tank closest to the engine? the one with the hinged lid? thanks Dafydd.
Dafydd Tai Hirion
Re: fuel tanks
Post by Villiers on Wed Aug 21 2013, 20:41
Its called a tool tank....
Re: fuel tanks
Post by Dafydd Tai Hirion on Wed Aug 21 2013, 20:50
There is a pipe going to the bottom of the mixer on it, with a filter in the tank, definetaly not a tool box/tank.
Dafydd Tai Hirion
Re: fuel tanks
Post by Villiers on Thu Aug 22 2013, 06:55
water injection then, or oil.
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 07:06
Water? Could be. Do i need to run the engine on petroil or just petrol? I have another crossley 3hp closed crank aswell, there is too mixers on that? What are there for? Thanks
Dafydd Tai Hirion
Re: fuel tanks
Post by Villiers on Thu Aug 22 2013, 07:10
The Crossley will be petrol/paraffin, start on petrol, get it warm then run on paraffin. You can run on petrol alone, it isn't going to do any harm.
Can you put a photo of the Bamford on here so we can see the "third tank"?
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 07:38
Thanks. Yeah. Sure.
Dafydd Tai Hirion
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 08:10
Dafydd Tai Hirion
Re: fuel tanks
Post by Villiers on Thu Aug 22 2013, 15:43
No photo....
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 16:01
http://www.servimg.com/image_preview.php?i=1&u=18486565
Dafydd Tai Hirion
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 16:02
Does that work?
Dafydd Tai Hirion
Re: fuel tanks
Post by Villiers on Thu Aug 22 2013, 16:08
That worked, I'd go with water for water injection but I'm not 100% sure.
Re: fuel tanks
Post by Villiers on Thu Aug 22 2013, 16:10
You can sign up to the IF website and download a manual from there.
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 16:20
Ohh yeah, can you please explain more about the water? Do i really need it? Or can i just run her on petrol? IF Website? Sorry, im new to this, founded these 2 engines in an old barn and i would like too get them running again! Thanks
Dafydd Tai Hirion
Re: fuel tanks
Post by Villiers on Thu Aug 22 2013, 16:22
IF is the Internal Fire web site...
http://www.internalfire.com/index.php
If it is water injection that is used when working to help stop "Pre ignition" of the fuel when working hard so you wouldn't need it for just play running on petrol.
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 16:26
Ohh yeah, i understand. So i would be better off without it then. Thank you yery much for your help. I will check out that website asap! Thanks.
Dafydd Tai Hirion
Re: fuel tanks
Post by Villiers on Thu Aug 22 2013, 16:28
Keep it there, it's part of the engine just clean it up and don't use it.
Re: fuel tanks
Post by Dafydd Tai Hirion on Thu Aug 22 2013, 16:43
Yeah. I will, i,ll have to rebuilt it, its rusted beyond repair, not like the other tanks! So water could be the reason for all the rust.
Dafydd Tai Hirion
Re: fuel tanks
