Axel Clamps
Axel Clamps Empty Axel Clamps
Post by Abes Sun Aug 25 2013, 10:37
Does anyone know what these type of axle clamps are called and any where that I might get a set from, need them for an idea for a new barrow trolley I am thinking of putting together
Axel Clamps Axel_c10
Axel Clamps Empty Re: Axel Clamps
Post by Motorhead Mon Aug 26 2013, 18:36
Like these? http://www.ebay.co.uk/itm/Axle-Brackets-for-Iron-Wheels-1-shaft-Closed-Type-Pk-of-2-Stationary-Engine-/130974265105?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item1e7eacaf11
Motorhead
Motorhead
Post by Abes Mon Aug 26 2013, 20:44
Hi mate yer there the type but need the open not the closed ones just have to keep looking me thinks
Motorhead wrote:Like these?  http://www.ebay.co.uk/itm/Axle-Brackets-for-Iron-Wheels-1-shaft-Closed-Type-Pk-of-2-Stationary-Engine-/130974265105?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item1e7eacaf11
Post by Appletop Mon Aug 26 2013, 20:46
Get the grinder out and open up the other side, you could always put the side you grind on the inside if you make a balls up of grinding it out.
Post by JONESEY Mon Aug 26 2013, 21:24
Abes I have found them there here I will see if I can sort the wood out tomorrow
Post by Abes Mon Aug 26 2013, 23:00
PM on its way mate
JONESEY wrote:Abes I have found them there here I will see if I can sort the wood out tomorrow
