Metal spraying.
Metal spraying.
Post by EarlBathurst on Tue Sep 03 2013, 20:40
Hi all.
Does anyone know of a cheap place that does metal spraying?
If all goes to plan there will be another engine in my Shed next Saturday, its been restored but has run the main bearings and will need the crank skimming then building up, or so i'm led to believe! but until i get it home and look inside i cannot be sure!
i won't say what the engine is just yet but i may be asking around for another crankshaft instead. watch this space !
__________________Question
affraid 100ish Allens,1xListerH, 7xListerD's,3xListerA's,2xListerB's,1xListerJ,1ListerLH,2xListerM's,1xListerN,                 1xwolseleyWD11,1xWolsleyWD8,1xRuston1.5PB 1xRustonPB3hp,1xRustonPT, 1xLister CS9/1, 1xAmanco3-1/2hp.
EarlBathurst
http://www.johnallenofoxford.webs.com
Re: Metal spraying.
Post by Lewis MacRae on Wed Sep 04 2013, 15:25
is it british?, horizontal or vertical. (but then seeing pics of your collection is most likely a Lister!!!)
Re: Metal spraying.
Post by EarlBathurst on Wed Sep 04 2013, 15:32
Lewis MacRae wrote:is it british?, horizontal or vertical. (but then seeing pics of your collection is most likely a Lister!!!)
It's a type that I've not got, its hopper cooled and vertical !
And Brittish !
EarlBathurst
Re: Metal spraying.
Post by EarlBathurst on Sat Sep 07 2013, 19:49
Well it's followed me home today, just after a blowout on the trailer!
here is a first piccie;
EarlBathurst
Re: Metal spraying.
Post by matt86 on Sat Sep 07 2013, 20:38
petter m appletop 3 hp ?
Re: Metal spraying.
Post by EarlBathurst on Sat Sep 07 2013, 20:42
EarlBathurst
Re: Metal spraying.
Post by matt86 on Sat Sep 07 2013, 20:46
thats was a good guess then Laughing
looks quite good condition , you soon have her running and spitting oil over your roof !
Re: Metal spraying.
Post by Lewis MacRae on Wed Sep 11 2013, 06:05
Looks great does it run?
Re: Metal spraying.
Post by Lewis MacRae on Wed Sep 11 2013, 06:06
Is there a flywheel missing?
Re: Metal spraying.
Post by EarlBathurst on Wed Sep 11 2013, 06:11
Lewis MacRae wrote:Is there a flywheel missing?
No. That side was stil dismantled when I brought it home and was in the boot of my car !
EarlBathurst
Re: Metal spraying.
Post by EarlBathurst on Wed Sep 11 2013, 06:16
Lewis MacRae wrote:Looks great does it run?
It's capable of running but has an issue with binding up in the bore and is now stripped for the liner to be skimmed and rings to be gapped !
EarlBathurst
Re: Metal spraying.
Post by EarlBathurst on Wed Sep 11 2013, 19:30
Hi all, after another evening working on the Petter , i had got to the point where i going to refit the piston rings onto the piston and all was going well until i got to the last one and you guessed it ,crack ! i broke the damn thing, So my question to you is; does anybody have a spare 3-3/4'' ring to fit a 3hp M ? if not where is the best place to obtain one please?
Off to a dark corner to sulk now ! ,Karl. lol! lol!
EarlBathurst
Re: Metal spraying.
