What engines do we all have then?
Page 1 of 3 1, 2, 3  Next
Post by Matth92 on Sun Sep 15 2013, 19:22
Lets see some photos of what we have got lurking in our sheds....I'll go first! Apologies for some of the photos, taken on my phone!
1931 Lister D shafty, bought it a few weeks back, currently having a mechanical restoration, she is looking much better now, has a very large heavy flywheel, so we think its a 1hp even though its badged as a 1.5, she has cleaned up quite well now with some original paint, watch this space for when she is back together!
1945 Lister F, bought her in june, new trolley, and a bit of work to get it running properly, runs nice and slow like a D now instead of revving away at 1300
c.1935 Moteur Bruneau Superbloc, purchased last winter as a non runner, magneto drive made, mag fitted, new trolley etc
1932 Villiers WAH WX11 fitted to an Alfa Laval milking set, engine bought as a runner, milking plant mechanically restored by me about 6 years ago, when I first started in showbusiness
1946 Bamford EG1, bought as a non runner in 2010, new trolley, sold it last year, and It came back again!
1945 Wolseley WD2, purchased as a non runner last summer, have fitted new rings, new mag and a trolley
1938 Ruston PT, purchased winter 2011 as a non runner, as a tank cooled engine, but have converted it to hopper cooling as I prefer it.
This is how it looked when I bought it, hideous!!
1951 Petter W1, bought in 2010 as a non runner, and put on the trolley, the first time I ever showed it a governor weight flew off and ruined all the gears inside, luckily at the rally there was a rough old A1 in the auction so I bought that and robbed the gears
1942 Fowler 1PA, Swapped it a couple of years ago for a Scott PAB, the magneto is away for repair at the moment so she will probably not get rallied this season now, she picked up a trophy at three okefords last year
1946 Avon (Bradford) drag saw engine, bought as a runner spring 2011, but has had a new trolley and a few minor tweaks
1956 Japy TY2, purchased in 2011, then I sold it on, and it came back again last year, has had new trolley, a problem with the main bearings sorted  but it has taken a lot of tweaking to get her running right, starts and runs well now but was very tempermental to begin with
Re: What engines do we all have then?
Post by Lewis MacRae on Mon Sep 16 2013, 16:29
Well here it goes,
1946 Wolseley WD 11 and Parker Pump set, Originally went to the forestry commission. Bought by my grandfather at a displenish sale.
Wolseley WD 2 and Parker pump by LewizMacRae, on Flickr
1942 Lister D Bought and restored by my grandfather as his first restoration. Originally went to Belgewnie engineering and dairy company from Aberdeen. It needs a decoke and possibly new rings
lister D by LewizMacRae, on Flickr
1951 Lister D, it was bought at Farming Yesteryear 2012 as a none runner, all it needed was the float raised. currently under restoration. Originally owned by George McLean of Dundee
Lister D Before Restoration by LewizMacRae, on Flickr
1926 Lister L, was restored by my grandfather from his wheelchair!
Lister L by LewizMacRae, on Flickr
1938 IHC LAA bought by my grandfather, sold by my granny then bought back early this year. didn't take much to get running Ie checked the point and put fuel in it and away she went!  I got second with it at Farming yesteryear 2013
IHC LAA and stuart pump by LewizMacRae, on Flickr
International LAA by LewizMacRae, on Flickr
19?? Amanco Chore Boy, bought a Few months back, took to show, took piston out and came across  a rough patch so needs a liner
Amanco Chore boy by LewizMacRae, on Flickr
19?? Crossley 1030 Bought a few months back but needs a wee bit of work
Crossley 1030 on the movable dolly before being winched by LewizMacRae, on Flickr
19?? Fairbanks Morse 3HP Z Type bought alongside the crossley
Fairbanks-Morse Z 3HP by LewizMacRae, on Flickr
Post by lister dan on Mon Sep 16 2013, 17:01
wolseley wd8 brought as a non runner at abbey hill soon made a trolley and got it running.
1951 Lister LD1 i was given this by my uncle two years ago
1955 Lister D
Lister a.
lister d
lister d anti clock
ruston pt
lister b
lister dk
hopfully a petter m 3hp
1949 Lister d 1955 Lister D,1937 Lister A,1928 Lister A,1954 Lister B, wolseley wd2,wd8.
Cheers Daniel.
lister dan
Post by Andrew1971 on Mon Sep 16 2013, 17:47
Hi All
My petter A1 just needs some tlc to get her better again and its my only engine at the moment. Making one good engine out of 2:)
Sorry for the bad pic taken on my phone.
Andrew
Post by kevjhnsn on Tue Sep 17 2013, 00:21
villiers wx11 wat
one of my open cranks AMANCO 2 1/4hp petrol/parrafin throttle guverned as can be in the "stationary engine mag" this month
will be more pics when the photo uploader is back online again ????
Post by callum12 on Fri Oct 04 2013, 20:05
Heres my engine,
She is a lister d type, given to me by a friend along with a lancaster bomber generator (24V) as seen on background. its standard rotation 1.5HP@700RPM. she's currently under going a mechanical restoration and bits that are missing are being added E.G: fuel tank and line.
hope this is interesting
Callum:D
callum12
Post by matt86 on Sat Oct 12 2013, 14:36
thought about time i should add a few on my collection ...been shrinking latley but only to clear a bit of room for more projects ..
IHC M 3 hp it has run but need a bit of work to get fuel tank in and fuel fitting with fuel pump and remove crankcase cover to fit another bearing in .
Lister A which has been rallied quite a lot in the last season  ,thinking the fuel tank would look better if was to paint it a mat black or with grate black .
amanco chore boy 1 3/4 hp latest project which just needs finishing and putting on a trolley once its been made .
Fowler 1pa needs finishing with a exhaust and the carb needs sorting .
joseph evans no2 pump ready to rally , needs a clean from the dust from great dorset .
Fairbanks morse headless had this one around a year now runs but needs a trolley making and a repaint along with a fuel tank but that the winter project .
Post by Lewis MacRae on Sat Oct 12 2013, 16:08
That's a good collection matt like the m 3hp
Post by Villiers on Sat Oct 12 2013, 16:50
From the left....
Petter M 1.5hp, Ruston BPR 4.5hp, Lister DK 1.5hp, Petter M 3hp
Petter M 5hp(now sold), Villiers D415 7hp, B&P pump, Petter A1 3hp, Bamford EG1 1.5hp, Villers WX11 1'5hp(behind pump) Godwin A2 pump.
Goulds pump, Lee howl pump, some well head, Bamford gear pump
Man killer.....
Post by matt86 on Sat Oct 12 2013, 17:07
thanks Lewis , i do like the IHC M as well thats why i bought it , i wouldn't mind a 1 1/2 igniter fired one someday .
Rob you have forgotten 1 pump .... Lister domestic !
Post by Lewis MacRae on Sat Oct 12 2013, 17:14
That would be nice!
Post by matt86 on Sat Oct 12 2013, 17:25
Lewis MacRae wrote:That would be nice!
exactly since having a clearout i have got more space so you can see whats coming ..... but i really must finish some of the others 1st .
Plus i will be after a wolseley wd to run a power hacksaw for cutting steel ..... i know would be easier just to bolt a electric motor under it you say but where is the fun in that .... ? and dont want to be upsetting neighbours so a wd is nice and quiet was going to have a lean to or a small shed where i can house it in .
Post by Foden on Sat Oct 12 2013, 17:31
1947 JAP 2a and Brooke pump.
1950 Villiers mark 10 shearing set
1936 Lister DK and Gascoigne milking set
1930 Lister D shearing set
JAP 2a Alco Pump
1944 Ruston PT and Fullwood dairy set
1942 Briggs model A
Villiers C12 Fullwood milker
1943 Briggs model I
1944 Briggs model B
Bernard W2
1929 Lister D type
There are others but that will do for now!
Post by Lewis MacRae on Sat Oct 12 2013, 17:31
Didn't you have a WD?
Post by matt86 on Sat Oct 12 2013, 17:33
yes i did i love those little engines .
Post by matt86 on Sat Oct 12 2013, 17:35
Pete , i think you need to get something done with your bernard !
With the amount of engines you got you could have your own private rally !
Post by Foden on Sat Oct 12 2013, 17:46
matt86 wrote:Pete , i think you need to get something done with your bernard !
There is also another D type, a Ruston PB6, Petter A1 and a Wisconsin AK kicking around as well.
Post by Lewis MacRae on Sat Oct 12 2013, 17:52
Foden, you have some nice engines! That Bernard looks quit big?
Post by matt86 on Sat Oct 12 2013, 17:54
Lewis MacRae wrote:Foden, you have some nice engines! That Bernard looks quit big?
not that big around same as a D in height but wider at bottom .
Post by Villiers on Sat Oct 12 2013, 18:04
[quote="matt86"][quote="Lewis MacRae"] but wider at bottom .
matt[/quote]
Nothing like a fat a r s e!!
Post by matt86 on Sat Oct 12 2013, 18:06
Villiers wrote:
Lewis MacRae wrote: but wider at bottom .
iagree lol! lol! lol!
Post by kevjhnsn on Sat Oct 12 2013, 18:43
kevjhnsn wrote:
villiers wx11 wah brass head
second world warish 1940-46 villiers wx11 wah brass head
then theres this lot in the front two rows and as many again to be finihed
the likes of bsa 120cc waterpump set ,villiers 25 4.5kva genset ,jlo outbourd engine, jap 2s ,jap 5,ww2 tinytim tank charger set,another amanco 2 1/4hp vapouizing engine in need of some loving back to life wolseley wd8, lister cs 10/1,medows 4 cylinder 5.4ltr  28.5kva 415/240 and 110volt set
lister 3 cylinder dynastart set up complete on casst base and slatebourds, and a 4 cylinder lister as before ,but electrics bourd is on display in my local war museum, safe and dry until i need it againpetter a1vo and a few B & SRATTONS ,
then the list goes on again
villiera wx11 LZHA pre 1932
villiera wx11 LZH pre 1930
frank pearn air/water pump and told it was designed to work as a steam engine originally but records are hard to find on the company in general
villiers diesel D270
VILLIERS WX11 WAH        ALLOY HEAD
wx11 WAHA  high speed unsilenced cast stand  base  yr 1935-48 special order undatable one of 12 made for order
and the rarest model a wx11 LZ  tank cooled 1927 one of 300 ever made and only 10-15 left in the world:D Very Happy
Post by matt86 on Sat Oct 12 2013, 19:08
Kev how you fit them in your shed ?
i think you should get a picture up of your sheds in the sheds topic i have started .
Post by kevjhnsn on Sat Oct 12 2013, 19:39
matt86 wrote:Kev how you fit them in your shed ?
rack them and stack them mate
just done the first of shed pics
others to follow soon
Post by Foden on Sat Oct 12 2013, 20:52
Three more.
1944 Wisconsin AK
1947 Wolseley WD2
1945 Lister DH, my first engine at its first rally!
