removing alcon pump
removing alcon pump
Post by ryno on Sun Sep 22 2013, 08:14
morning all.
im having problems removing an alcon pump from my villiers mk 10, all 4 bolts came away from the engine ok, just can't get the pump away from the engine..
thanks in advance, ryan.
ryno
I really need to post more
Re: removing alcon pump
Post by kevjhnsn on Mon Sep 23 2013, 03:39
the alloy pump casing is a 2 piece so the usually comes away so you can get to rotor that is fixed to the end of the engines crankshaft
alloy and steel+ water over the years makes the need for a very good soaking in diesel or gt40/wd40 ,just the soften up the corrosion between the joints
Post by ryno on Mon Sep 23 2013, 17:46
yeah got the front cover off, just decided that i'll leave it and give the inside of the pump a good clean in situ,
also i need pointing in the direction of a pull rope for it and the air filter bit for the b10 carb.
cheers
ryno
Post by kevjhnsn on Tue Sep 24 2013, 00:35
ryno wrote:yeah got the front cover off, just decided that i'll leave it and give the inside of the pump a good clean in situ,
cheers
and make sure the rubber none return flap is still complete on the front cover inlet hole,otherwise it will be a bugger to get pumping , as you have to fill it to the top manualy with a good flap with 2-3 gallons to get it to start pumping on a good one , but once bleed will pump all day till the waters all gone
filters for b10 b10-1 b10-2 carbs are a bugger to get on there own and cheap
try a company called meetins ,there usually in the stationary engine magazine with a red coloured advert towards the rear of the magazine
do you mean a pull rope or a recoil starter rope ???
Post by ryno on Tue Sep 24 2013, 04:41
thought the filter would be hard to find,,,
yeah a pull rope, got nothing to start her with.
the non return flap is the and complete, just very grubby but will be fine
ryno
Post by ryno on Thu Sep 26 2013, 18:39
got rope now, and all back together, just need to know the easy way to time her up. thanks
ryno
