Lister Domestic Water Pump
Post by Gary.B on Sun Sep 22 2013, 20:51
Picked up a Lister domestic water pump this week, managed to get it stripped down today. Happy to find that the bearings and oil seals look in great condition, it really just needs a good clean up.
I don't actually have a clue what I'm doing. Rolling Eyes
Gary.B
Re: Lister Domestic Water Pump
Post by matt86 on Mon Sep 23 2013, 07:09
Great little starter pumps these are, just make sure you get the flap valves right way up on the plate in the vessel.
Post by Gary.B on Mon Sep 23 2013, 18:34
matt86 wrote:Great little starter pumps these are,  just make sure you get the flap valves right way up on the plate in the vessel.
Cheers I'll try and remember that. Smile
Gary.B
Post by chrismac on Thu Sep 26 2013, 16:05
Looks a great find.
you are certainly getting prepared for next season.
Chtis
chrismac
I really need to post more
Post by Gary.B on Sat Sep 28 2013, 15:40
Spent an hour this afternoon removing all the loose rust.
Gary.B
Post by billypurves on Sun Sep 29 2013, 19:09
Hi Gary, Will you paint the pump or leave it as is? Bill.
billypurves
Post by Gary.B on Sun Sep 29 2013, 20:34
Hi Billy
I like it as it is, I'll be running it off my 1951 Wolseley WD8 which hasn't got a fancy paint job so I'll probably leave it for now.
Gary.B
Post by billypurves on Mon Sep 30 2013, 20:28
A amn after my own heart. Where about are you? PM me if you wish. Billy.
billypurves
Post by Gary.B on Tue Oct 01 2013, 20:22
I'm up in Caithness Bill.
Gary.B
Post by Gary.B on Sat Nov 09 2013, 11:27
Can anyone tell me if this is the correct fittings for the inlet and outlet on the Lister domestic water pump?
http://www.screwfix.com/p/conex-male-elbow-402-22mm-x/85054#product_additional_details_container
Gary
Gary.B
Post by Villiers on Sat Nov 09 2013, 12:10
[quote="Gary.B"]Can anyone tell me if this is the correct fittings for the inlet and outlet on the Lister domestic water pump?
Gary[/quote]
Yes.
Post by Gary.B on Sat Nov 16 2013, 11:41
Slow progress but getting there.
Gary.B
Post by Gary.B on Sat Nov 30 2013, 13:43
I've bought a new oil seal for the pump, can anyone tell the best way to replace it?
Thank you
Gary
Gary.B
Post by matt86 on Sat Nov 30 2013, 14:03
the oil seal on the main pump rod ? matt
Post by Gary.B on Sat Nov 30 2013, 14:11
Yes Matt.
Gary.B
Post by matt86 on Sat Nov 30 2013, 19:42
ah thats easy ..
On the front of the pump unscrew the plug and unscrew the piston , should be a nut on the front you can get spanner on failing that get the grips on the brass or bronze rod but careful not to mark it like use a rag in jaws etc . and the there should be a while washer that is called a drip wiper that just sits on the rod made from rubber i think ( have one here if you would like it for the postage , its new ) . There there is a small steel cup that holds the seal in either remove the cup with the seal in or just hook the seal out and replace . Tip tap the new seal home with a socket the same size as the outer diameter . then resemble .
If get stuck give me a Pm .
Post by Gary.B on Sun Dec 01 2013, 15:53
Thanks a lot Matt, got it sorted. Going by the photo do you think that it's in enough? That's as far as it will go without getting too heavy handed with it.
Gary
Gary.B
Post by matt86 on Sun Dec 01 2013, 16:44
hasn't the cup got a recess in it when you took the seal out ? if it has i would knock until bottoms out or until the seal is flush with the cup .
Ps do you want this wiper seal ?
Post by Gary.B on Sun Dec 01 2013, 17:28
I'll give it another go tomorrow, but I think it may have bottomed out. Yes I would like the drip washer if that's ok, shall I post you a stamped address envelope, would that be the easiest way?
Gary
Gary.B
Post by matt86 on Sun Dec 01 2013, 18:42
Gary.B wrote:I'll give it another go tomorrow, but I think it may have bottomed out. Yes I would like the drip washer if that's ok, shall I post you a stamped address envelope, would that be the easiest way?
Gary
garry im sending you a pm
Post by Gary.B on Sat Dec 14 2013, 13:53
Getting there.  Smile
Gary.B
Post by matt86 on Sat Dec 14 2013, 16:41
slow and stead wins the race .. did you send of the SAE ?
Post by Villiers on Sat Dec 14 2013, 17:56
All very good but..... Your crank is in the wrong way round, it should have the drive pulley on the right hand side as viewed from the head, not a problem with what you have there but you are driving it the wrong way and as the "Domestic" has a scooped big end cap you will be starving the big end of oil.
Post by Gary.B on Sat Dec 14 2013, 21:27
Yes Matt it's on the way. :-)
Thanks Villiers I'll flip it tomorrow. I'm glad I didn't run it for long today.
Gary.B
Post by Villiers on Sat Dec 14 2013, 21:43
Top man.
