Lister Domestic Water Pump
+4
billypurves
chrismac
Gary.B
8 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Lister Domestic Water Pump
could always cheat and twist the belt
I had the same thoughtmatt86 wrote:could always cheat and twist the belt
is that a 2.25hp wd8 by any chance? looks to be running quite fast
If you want it to slow down you'll need to modify the governor
blackvanman- Life Member
I know a guy that did that with a lister F governor to slow it down, I think he used a Lister D one and converted it!
No, its more simple than that on a wd8, you remove the adjustment screw and drill another split pin hole about 3mm from the end at 90deg from the original and use the smallest split pin you can, it then lets you wind her right down at 2.25 hp they are set up to run at 900rpmLewis MacRae wrote:I know a guy that did that with a lister F governor to slow it down, I think he used a Lister D one and converted it!
[quote="blackvanman"][quote="Lewis MacRae"]I know a guy that did that with a lister F governor to slow it down, I think he used a Lister D one and converted it![/quote]
No, its more simple than that on a wd8, you remove the adjustment screw and drill another split pin hole about 3mm from the end at 90deg from the original and use the smallest split pin you can, it then lets you wind her right down :)at 2.25 hp they are set up to run at 900rpm[/quote]
The 3hp WD was set to run at 1250rpm, bit odd when you think Petter set there A1 3hp engines at 1500...
Actually runs nicer with the pulley on the correct side.
Thanks Villiers.
I don't actually have a clue what I'm doing.
Gary.B- Expert
That WD runs well!
If you want to "load" the pump you can reduce the 22mm down to 10mm on the outlet, this will give the pump some resistance and make the engine work(look crap though)
Villiers wrote:That WD runs well!
could a sleeve be knocked up that goes over the 10mm pipe ??
It could, or just fit a reducer on the end.
good pointVilliers wrote:It could, or just fit a reducer on the end.
The longer the reduced pipe run the better though.
Villiers wrote:The longer the reduced pipe run the better though.
as i thought , as the discussion erlier .
to use the extra pressure produced perhaps culminating in an ornate garden fountain display instead of just reducing the outlet could be the next rally craze.....
Page 2 of 2 • 1, 2
» Lister Domestic Water pump - air chamber bleed screw (?)
» Just got hold of a lister d and domestic water pump
» Lister Domestic pump
» Lister Domestic Water Pump Type 187
» Initial advice for a Lister Domestic Water Pump
Page 2 of 2
