removing stains off float bowls
does anyone know a good way of removing stains and dulness of float bowls, i really want to bring the shine back out in it
Re: removing stains off float bowls
Removing stains??? What have you been up to?
Seriously, I swear by these things - cover them in oil, and get polishing...
http://cgi.ebay.co.uk/10-Faithfull-Red-Abrasive-Scouring-Pads-230mm-x-150mm_W0QQitemZ330264101083QQcmdZViewItemQQptZUK_BOI_Building_Materials_Supplies_Carpentry_Woodwork_ET?hash=item4ce54640db
Those seem a bit pricey though - if I remember correctly they're cheaper from MacSalvors at Camborne :-)
Hope and Crank- A credit to the forum
Ryan get your self a cheap bench grinder swap one of the grinding wheels for a brass wire whell only £10..00
Easy peasey
Easy peasey
Hi Ryan,
Try Brasso its abrasive but not hard on the surface, might do the job.
Let us know how you got on.
Mix a bit of Ferterlizer up with water make into a paste, wicked .
Make sure you have some rubber gloves on if you have a cut on your hand it kills you
Ryan,
I use Fine Wire Wool dipped in Brasso, Works a treat mate.
Martin
Martin
BRASSO- Life Member
once you get the bowl upto a shine your happy with, spray on some high quality lacquer to keep the finish you desire.
» Jap 2a removing points cam
» Removing a pulley
» Removing a JAP 2A flywheel
» removing alcon pump
» Carb float
» Removing a pulley
» Carb float
