Villiers Date of Manufacture please
Hello, I have a MK20 Villiers 4 stroke, its numbering is as follows :-
281D 71011 can anyone date this engine for me ?
Thanks
Thanks
Slim- Born to be wild
Re: Villiers Date of Manufacture please
if you give me the numbers of the flywheel inside and out ,
the numbers you give should be a later one with a one piece cowling with the alloy plate in a pressed in plate sized and shaped divert
i can usually get it to the month with the flywheel mag numbers "if your looky ,pics also help as i know all the little tweeks over the yrs of production to within 10yrs ,there is now official records of factory production ,but ive sofar always been able to date them within a 2 year window of the stamping when ive been looky enought to find the on restoration
I've found the following on the brass flywheel outerkevjhnsn wrote:if you give me the numbers of the flywheel inside and out ,
R203A203 3/62
Thanks
Dale
daleSlim wrote:I've found the following on the brass flywheel outerkevjhnsn wrote:if you give me the numbers of the flywheel inside and out ,
R203A203 3/62
Thanks
Dale
there it is ,yours is leaving the factory stores in appox
march 1962 to april 1962 as mags were fitted just before delivery or even after delivery if going to the likes of burgess`s or atco ect
Thanks, I didn't think the engine was that old, I assumed late 60's early 70's. Umm - its older than me.
Regs
Dale
Regs
Dale
they were made for about 40 years
heres my early mk25 etrol parrafin running made 1944
the only main difference on earlyer ones was a split cowling design ,mine turned out to be a rare bugger with a villiers vapourizer fitted and twin fuel tank
the engine under tin works is identical to the end of production
Villiers Date of Production please?
Can anyone help me date my engine please? It is a Villiers 4 stroke MK12 120cc with kickstart. The instruction plate has the number 284C 96332A 12 and on the Dynamo flywheel and backplate are the following numbers and letters.
M325BA71E4 59
BM502/3
V1278
M2663C
42 with a circle around it.
M5 with a circle around it
M325BA71E4 59
BM502/3
V1278
M2663C
Thomas Green- Posts : 3
» Identifying the the year of Manufacture
» Lister D date of manufacture
» Lister Dating
» Villiers D15
» Lister Dating
» Villiers D15
