Lister Domestic Water pump - air chamber bleed screw (?)
Post by Porteous on Sun Oct 20 2013, 22:15
I have just acquired a DEP 1 pump with a broken air screw assembly on the top of the air chamber. What does this do? If it is just a bleed screw then can I fit a cheaper 1/8 BSP radiator bleed valve instead?
Porteous
Re: Lister Domestic Water pump - air chamber bleed screw (?)
Post by Villiers on Sun Oct 20 2013, 22:18
You can, the idea of the bleed screw is just that, the air chamber works as a "damper" to take the knock or "water hammer" out of the joining pipework caused by the piston, by adding or removing air as needed this works as a "cushion". If the pump is only for rallying then I would just put a 1/8 plug in it and leave it at that as you would not have enough "back pressure" to cause the pipes to "knock".
Post by Porteous on Mon Oct 21 2013, 10:23
Many thanks, that solves a pocket problem!
Porteous
