Oldest known petter av1 in presevation
Post by Mattjones on Fri Oct 25 2013, 23:49
Hello peoples. I was just wondering if anyone knows the oldest petter av1 series 1 in presevation ive got one which is serial number 600006 and was just wondering if there was any earlyer than mine in presevation
Mattjones
Re: Oldest known petter av1 in presevation
Post by Biggusdannus on Sat Oct 26 2013, 01:13
Your best bet is to contact Jim Perkins, he will be able to shed some light on when your engine was made and possibly who it was supplied to. Have a look here > http://www.petterengines.co.uk/contact.html Hope this helps Dan
Biggusdannus
Post by kevjhnsn on Sat Oct 26 2013, 02:20
sounds a good find
hope it turns out to be the case
Post by Mattjones on Sat Oct 26 2013, 06:12
Thankyou biggusdanuss will contact him the engines been in the family since 1951i think and it use to run a dynamo and later on moved onto a corn crusher but it was lucky it suvived the scrap as we had a cs and a hornsby ackeroid (probably not correct spelling) but was very exited when I read the serial number plate
Mattjones
oldest av1
Post by reiver on Sun Oct 27 2013, 21:09
Hello
I have a series one AV1 ser no 604044 which jim Perkins dated as 1949 ,so I would think yours maybe even earlier
reiver
I really need to post more
Post by Mattjones on Mon Oct 28 2013, 03:16
I think they started making the av1 1946 I think , ive just started to strip the head off to see why its not starting do you have any trouble getting yours started reiver
Mattjones
Post by Mattjones on Fri Mar 14 2014, 23:35
Rebuild starting after many months sitting in the shed a big thankyou to mr jim Perkins for sorting me out spares with luck she might fire up first time reground the valves so should have better compression fingers crossed
Mattjones
Post by Mattjones on Wed Apr 02 2014, 21:23
Engine rebuilt with new parts and head gasket better compression and fuel getting up to the injector but still wont put in to life theres smoke on compression but not firing woyld there be anything else to check matt
Mattjones
Post by RAB on Fri Apr 25 2014, 20:13
The Series 1 was a bit of a bandit to get started from what ive heard, hope you have luck with it,
Dont learn tricks of the trade, learn the trade itself !!!!
