New Toy/Unknown Engine
Post by Hughesy on Sat Oct 26 2013, 19:17
Hello
I have been out today and bought a new toy, freshly imported from the states. In need of a bit of work but is complete
Now im not sure what it is, I bought it as a Maynard engine. But looking around i now believe it is an ottwa log saw engine.
Its 1 1/2hp
Low tension
Hit and miss.
Can anyone identify it for me.
Sorry for the bad pictures.
Many Thanks Lewis
Re: New Toy/Unknown Engine
Post by Villiers on Sat Oct 26 2013, 19:26
Looks like an Ottowa to me
Post by Hughesy on Sat Oct 26 2013, 19:27
Looks that way. Anyone date it for me then.
Post by Lewis MacRae on Sat Oct 26 2013, 19:37
hi Lewis, Looks like a great import to me! are you restoring it? Also looks like it should have a Webster mag, do you have the mag?
Post by Hughesy on Sat Oct 26 2013, 19:56
certainly do have the magneto but the threads and part of the base have been pulled out. we believe it has been hit and broken away.
I think i will just linseed oil it. As its showing through green paint and the signwritting is showing through both sides.
Heres the webster
Many Thanks Lewis
Post by Lewis MacRae on Sat Oct 26 2013, 20:03
ye, think that would look great just linseed oiled!
Post by matt86 on Sat Oct 26 2013, 20:23
nice one .
us tractors again ?
Post by Hughesy on Sat Oct 26 2013, 20:27
certainly was matt.
Post by kevjhnsn on Sat Oct 26 2013, 22:47
sweet lump of rust there mate
rust id like to have in my shed anyway
looks like a saw engine with that casting going over to the pulley side
there maybe linking point  for saw motion hidding in the middle of wood or a gear "not to hot on this make to be honest but theres a few others that will be far more helpful than i can be
hoping the linseed brings the paint and details out far more for you as it looks posable from the pics
i have an engine i was going to linseed ,but it looks more like 100% rust and no remains of paint😢 Crying or Very sad  so may have to " polish a turd"
sorry had to get a turd polish in here somwere been quite a topic for a week or so Smile
Post by Lewis MacRae on Sat Nov 09 2013, 16:53
Hi Lewis, Have you been working on the Ottawa lately?
Post by Hughesy on Sat Nov 09 2013, 16:56
I have been working on it. Been waiting for parts mostly though. Got some new piston rings from the states which arrived the other day and are now fitted. I've also fixed the mag, I used fibreglass resin in the end which has held the studs.
I'm having the mag remagnitised tommorrow. So hopefully if that works it shall be running tommorrow.
Ill put some pictures up when I'm next on the computer.
Post by Lewis MacRae on Sat Nov 09 2013, 17:07
cool!
Post by Hughesy on Sun Nov 10 2013, 15:22
Hello All
I have got the piston back in the engine. got the broken piston ring off the piston. Then fitted the new piston ring.
Heres some pictures of the piston. The piston is 4 1/2 inch wide x 6 inch long.
http://illiweb.com/fa/pbucket.gif
The piston on the left is a standard lister d type, the piston on the right is the ottawa one. Bit different in size.
I have been over a good friend of mines and we have sorted the magneto out. The points where adjusted round slightly to make better contact. We then remagnitised it and it now produces a lovely blue spark.
Next thing was to get it running.
After timing it back up and sorting everything out. i attempted to start it, on the 4 pull of the flywheel she burst into life. It ran very quick indeed so after a few adjustments it was running better. I need to make a temporary trolley for it and get it staked to the ground. This will keep it steady and let me adjust it better.
Many thanks Lewis
