Villiers Midget mk2
Villiers Midget mk2
Post by bluedog on Tue Oct 29 2013, 11:22
I have started to disassemble a Villiers Midget Mk2 engine and am having difficulty with removing the flywheel. I can unscrew the nut a few turns but then it binds up and won't budge further. When loosened I can't turn the flywheel without the drive shaft turning. It is like the flywheel is seized on the drive shaft.
Any ideas much appreciated.
Also, what is the best way to remove rust stains from carburettors to end up with a nice finish?
Greg
bluedog
Re: Villiers Midget mk2
Post by Foden on Tue Oct 29 2013, 12:52
Greg the flywheel is 'self extracting' on Villiers. The nut has gone loose and then tightened again, now you need to put a spanner on it and clout it with a hammer, the nut will then go loose again and if you keep turning it will draw the flywheel off, simple!Wink
Post by bluedog on Wed Oct 30 2013, 10:07
Thanks Pete. It took a few wacks but then it came off.
bluedog
