RUSTON HORNSBY 6PB
RUSTON HORNSBY 6PB
Post by spit-bang on Sat Dec 28 2013, 14:16
Here are a couple of pics of my ruston hornsby 6pb. As you can see it needs a bit of work. it is missing its ID plate so i have no way of dating it, only that it is post 1943 as that is when i think they switched from the flat style silencer to the pepperpot type it has. Is there anywhere else i may find a serial number? it is on what i assume is its original skids. I am hoping to have it mechanically restored but left as is paint wise as it has a nice patina.
spit-bang
Re: RUSTON HORNSBY 6PB
Post by Lewis MacRae on Sat Dec 28 2013, 14:31
Try the flywheel as it might on there, I know is on there on Lister and other makes but not sure about Rustons. As for the engine well she's a nice one, once you get the parts that it needs im sure it will run great! (are you restoring it)
Post by Foden on Sat Dec 28 2013, 14:50
Just restoring a 6PB myself and I haven't found any numbers anywhere else I'm afraid.  All that is on the flywheel is the 'SPARK' and TDC marks.   Mine is 1942 so presumably (by what you are saying Spit-Bang) it should have the flate type silencer?  Mine was missing altogether (it had a tractor type exhaust) and I put a request out for the 'pepperpot' type, maybe I should be asking for the earlier sort instead? scratch  Drawn a blank so far either way!! Smile   I might have to settle for an Amanco type, though I have seen them with just a length of BSP pipe and they run quiet enough.  If the fuel tank has the bakelite filler cap then it will be from the WW2 area, my PT has both a bakelite spec plate and fuel filler and that dates from 1944.
Post by spit-bang on Sat Dec 28 2013, 15:26
I am just going by what i read somewhere about the silencers pete, so im not 100 percent sure. shame about the serial number but there you go. I cant tell about the fuel tank filler because its missing. should the tdc mark on the flywheel line up with the arrow mark cast into the engine? cheers
spit-bang
Post by Foden on Sat Dec 28 2013, 15:32
spit-bang wrote: I am just going by what i read somewhere about the silencers pete, so im not 100 percent sure. shame about the serial number but there you go. I cant tell about the fuel tank filler because its missing. should the tdc mark on the flywheel line up with the arrow mark cast into the engine? cheers
Yes, the TDC mark and the SPARK mark (for magneto timing) should line up with the cast arrow.  Are both your marks visible on the flywheel, if not then I can measure the distance between TDC and SPARK on mine for you?
Post by rubythursday on Sat Dec 28 2013, 18:45
Hi
I have 2 6PB one a 1939 with Villiers mag and one 1944 with Wico Mag. The 1944 has the serial number on the end of the crankshaft, the 39 doesn't.
pics here ruston 6pb
Tony Simons
York
www.tonysimons.me.uk
1913 Hornsby L Type 8HP, 1926 Blackstone 5HP, 1927 Lister D 'Shafty', 1940 Stuart Turner P5LY generating set, 1944 Ruston Hornsby 6PB, 1945 Wolseley WD2, 1946 Norman SC, 1971 Rover 2000 auto, 1990 VW T4 camper, 2002 Land Rover Discovery TD5 Auto, 2005 Volvo S60 auto.
rubythursday
http://www.tonysimons.me.uk
Post by spit-bang on Sat Dec 28 2013, 19:05
Thanks for that rubythursday, I will have a look on the end of the crankshaft. to pete I havent looked for the spark and tdc marks on the flywheel yet, will have a look tomorrow.thanks for your offer of measuring.
spit-bang
Post by Foden on Sat Dec 28 2013, 19:08
rubythursday wrote:Hi
ruston 6pb
I will check mine then Tony, can't say that I noticed anything during the cleanup but Specsavers might require visiting ! Embarassed
Post by spit-bang on Sun Dec 29 2013, 12:42
Ive had half an hour this morning with emery paper and managed to find the spark postion on the flywheel but not TDC. unfortunately had no joy either in the serial number search. stamping may have faded through time.
spit-bang
Post by rubythursday on Sun Dec 29 2013, 19:50
mine only have spark marking, no TDC mark
Tony Simons
York
rubythursday
Post by Foden on Tue Dec 31 2013, 00:17
No number on the crank on mine, maybe a wartime economy?  The spark mark is of more use than TDC anyway but I can measure the distance between the marks on mine if you wish?
Post by spit-bang on Tue Dec 31 2013, 14:20
No, Thats ok thanks pete. like you say, spark mark is most useful.
spit-bang
Post by walltiler on Wed Jan 01 2014, 17:42
hi looking for parts for my ruston class pr size 110
walltiler
I really need to post more
