pillow block bearings on trolley?
Hi all,
I've been getting some stuff together to make new trolley for my Lister D and i've come across some pillow block bearings. (see link) http://www.ebay.co.uk/itm/UCP-Metric-Self-Lube-Bearing-Pillow-Blocks-Normal-Duty-/320695884156?pt=LH_DefaultDomain_3&var=&hash=item4aaaf6d97c
I know that trollies really don't need any bearings as they only move a few meters at a time. But i think painted in a nice Mid Brunswick green it would really make the trolley look the part. especially because i have four spoked wheels so they would be very visible. It will also make the trolley more a part of the display rather than just an aid to help move it about. ( although some trollies are very nice indeed )
I was wondering if anyone has done this before? If not does anyone know whether they would be up to the weight and the thumping of the piston?
thanks,
callum
thanks,
callum
Re: pillow block bearings on trolley?
ive seen theses on trolley etc..
thanks for sharing them with us all callum
regards, mike...
regards, mike...
they would roll and be dead easy to push with those on them
Yeah pushing a Lister with your little finger! nothing a pair of chocks can't sort out when on the rally field though.
do you recon "normal duty" will be okay for a Lister D? I would think so as a D probably weighs about 160KG with oil, water and a tank of fuel, so thats only 40KG per pillow block. But there is also the constant thump of the piston to consider.
I think i will use pillow blocks on my trolley, it'll finish it off nicely i think.
Callum
Callum
They will certainly look good. Shame that sort of thing is so expensive. After you pay £40 to £80 for four spoked wheels, two lumps of decent wood and all the hardware the trolley can end up costing more than the "D" you built it for.
Motorhead- Born to be wild
I see what you mean about them being pricey, by if you think about it, there cast iron and the bearings are quite good according to other people so they should last a lifetime.
Callum
Callum
I just took delivery of the bearings today and they look good, they are the self aligning ones so they won't bind if I'm out a bit.
you will have to put a few pics up when done - thanks for the link by the looks of the phone number they are very local to me .
steve w- Life Member
yeah sure, i've been working on it today and they do good. they came to about £24 for the 4 and they are made by a company called challenge.
» New kid on the block !.
» Wolsley block
» First lister D, and first time everything else in old engines.
» JAP J.A.P. Model 5 rebuild - advice welcome.
» Vintage Oil and Bearings
» Wolsley block
