Before and After.
+7
110samec
A Lister
11 posters
Before and After.
A couple of years ago I was given a rather rough 1943 2hp Lister D; it was missing the carb float chamber, the fuel tank, spark plug and plug lead, and the magneto coil was open-circuit. It was quite rusty but still had patches of original paint on it and the transfers on the cylinder head/hopper were still just about visible.
I briefly thought about keeping it as an ‘oily rag’ type restoration but felt it was too far gone for that, as there are plenty of better examples of the Lister D in original paintwork out there. I also have a fully restored and repainted 1940 Lister D, so why would I want another? So the D was left in a corner of the shed while I got on with other projects and decided what to do with it. During that time I also had chance to find replacements for the missing and broken parts.
To paint, or not to paint, that was the question? I was struggling to decide… then I had a daft idea; why not just paint half of it?! The more I actually thought about this idea, the less daft it seemed... I could put an imaginary line right down the centre of the engine and restore and repaint the right hand side of it, but leave the left hand side with just a light coat of oil to slow the rust down. This would make an otherwise common engine a little bit more interesting for the rally-field, and the public could see an example of how us stationary engine enthusiasts can restore a rusty old relic to look and run like new, or to look old but still run like new!
I decided to start with the cylinder head/hopper to give me a good centre line to work from for the rest of the engine... but soon found the task I’d set myself was going to be a bit harder than I thought! The casting on this mid-wartime engine was much rougher than on my 1940 Lister D, which made measuring the centre line difficult as the sides weren’t particularly parallel. As you can probably imagine, the transfers were a bit of a nightmare to do as well. Not only did I have to cut them to join to the existing transfers, but the reproduction transfers also seem to be a slightly different size to the original ones (the original ‘Lister’ script is slightly bigger, but the rest of the text appears to be slightly smaller and finer than it is on the reproduction transfers I'd got). This meant I had to carefully cut down each line of text to reduce it's height slightly, then apply it separately, which wasn't easy for me. My hands are a bit on the large side for delicate work too; after two sets of transfers and some swearing I eventually managed to get it to look about right! Well, it's the best I could manage anyway!
The transfers were still drying out when this photo was taken, so they’re still slightly milky-looking, and the 50/50 boiled linseed oil & white spirit mix on the left hand side needs to dry for a few weeks before it can be handled. I still have to paint inside half the square plug, but need some good light before I do that! Anyway, the following photo should give you an idea of how its going to look once it’s finished:
I had chance for an hour or two in the shed earlier this week to start stripping the rest of the engine down for mechanical inspection and cleaning. Luckily I managed to remove the gib key without too much drama and take the flywheel off, so that should make things easier. I’ll post another update when I’ve made some more progress on ‘Before and after’. Thanks for reading and I hope you like it.
Jules.
Re: Before and After.
looks great, never seen it done before, reckon it will stand out on the rally field!
Good project , but polishing half the flywheel rim and leaving the other "old" will be a challenge !!
keep us posted, interesting project
jon
jon
A very nice original idea looking great so far well done
now thats different Jules .
looking forward to see whats like when is done , Matt
Looks really good I bet that plug will be a pain if you have to take it out to line the paint up again though!
Thanks for the comments chaps; I have a feeling this engine should keep me busy for the next few months!
I had a think about the flywheel rim Jon. I did consider taking half of it back to bare metal, but thought that half a polished flywheel rim flashing round in the sun at 1000 rpm might not be too comfortable for spectators! Then I remembered that Lister used to paint the flywheel rims on production Ds, so I thought I'd paint half and leave half. Hopefully, with it being a small flywheel, when the pulley is fitted it shouldn't look too strobe-like when it's turning.
Jules.
ive been bosting to spill the beans on this idea of jules for months ,but kept it under my cap like a good lad, just gave a few sneecky comments on other posting on here ,along the lines of you havent done a half a job restoration that ive seen "YET" ect ect
when i was arround jules the other for a brew or 2 and a chat ,i could clearly see the the point of the idea ,its a before and after all in one ,
its already starting to stand out from all the others hes done ,as they are done up the dogs bobbins,
well this does from one point of view:lol:
cant wait to see how he does half a trolley
Kev’s not the only one to have been making progress with his Lister D restoration, so I thought it was time I posted a progress update on my Lister D ‘Before and After’ project:
The engine was put on the workbench and completely stripped down for cleaning and inspection:
Which is just as well as it seems that someone had forgotten to drill the little end bearing oil hole!
Apart from that, everything appeared to be in good order and it seems this engine has done very little work, with no detectable wear… even on the gudgeon pin and little end bearing, despite the lack of oil hole. The crank-case was then cleaned out and the old engine oil and sludge was bottled up for safe disposal in the waste oil tank at the local recycling centre. Look at the gloop in there; imagine that getting mixed up with a pint of fresh engine oil and doing the rounds with the bearings! One reason I never try to get an old engine running again before cleaning everything out.
Once it was clean I could set about removing the rust and remnants of old paint from the ‘After' side.
The bore was then lightly honed to remove the glaze and the original piston rings were tried in the bore in various positions to assess the gap. This gaps were found to be well within tolerance, so the original rings were carefully refitted to the piston ready for reuse.
The paint job could then be continued on the ‘After’ side of the engine. However, when I came to fit the new gaskets I found the newness of them stuck out like a sore thumb on the ‘Before’
side. So I found a way of ‘antiquing’ them to blend in. Well, if half a job’s worth doing, it’s worth doing half properly…. or something like that!
Once the main parts of the engine were painted (or half painted!) I could start the re-build, and the bottom end of the engine is now back together again. I’ve just got the tank straps, flywheel and magneto bracket to give the ‘Before and After’ treatment to now, the inside of the water plug on the head needs doing, and the fuel tank has just had its first half coat of gloss. So nearly there now, but it's been a long and fiddly job!
I couldn’t resist a sneak preview of how it’s going to look the other day, so I placed the top and bottom back together for a quick photo. You'll see what I mean about the gaskets, as I just placed the head gasket on so I could mark the dividing line. It’s since been given the ‘antique’ treatment so blends in OK now. Thanks for reading, I’ll update the thread again once it’s all back together.
Jules.
Love this idea mate really look forward to seeing it all finished and running
abesAbes wrote:Love this idea mate really look forward to seeing it all finished and running
you mean half finished and running surely mate
jules
shes coming along well since i seen you last mate
looking great and different ,you must be over half finished now mate
just added the last of the top coats today to the shafty then i can start bolting it back together
just a load of old brass to polish and nuts when tightened down to final topcoat and maybe at weekend add some decals
while i still awaith the flaming piston and ring set to arrive end of month now there saying:x
that's a great idea,
steve w- Life Member
Looks great well done
marknva- Born to be wild
this is a great project, i will be following with great interest!
though, surely you should have only honed half the bore, how ever you could do that! i'm sure people would appreciate a healthy lister rather than that level of detail.
have fun!!
have fun!!
Jules, as much as I am loving this thread, would it not have been easier to have done the same idea but by splitting in half from the front view ? that way the problem of a half restored or fully restored flywheel would have been a simpler choice !! Good work mate
Janner
Janner
Thanks for the comments and encouragement chaps.
You're right Janner, it would have been easier to have restored either the front or the back half, but I think it would have lost some of the visual impact, particularly the effect with the old and new lettering. The idea of doing it this way is that people walk along the engine line and, depending which way they are heading, they notice a restored or unrestored Lister D, but as they get closer they go "Wait a minute... what's that!". If I'd done it the other way then I don't think people would noticed the 50/50 effect as much?
I won't be doing another engine like this though, that's for sure, talk about fiddly and frustrating. Masking it up for preparation and painting so it's straight and everything lines up has caused a lot of swearing! I think I'll just hose the next engine I restore off, slap a bit of 'panther pee' (50/50 boiled linseed oil and white spirit) on it, and job done!
Jules.
lol, yeh I know what you mean by fiddly, this Coventry midget genset has been a right royal pain, talk about fiddly !!!!!!
Some more progress on 'Before and After' since the last update; it's been mostly fiddly small stuff like sanding and painting nuts and bolts, throttle linkages, etc, so nothing very interesting to photograph and post on the Forum. There have been a couple of larger jobs though, such as the fuel tank and the trolley:
After a couple of years of searching I managed to find a sound fuel tank of correct spec for the engine. It had just enough original paint left on it to look in keeping with the engine, and came complete with a nicely tarnished brass fuel cap. The inside needed the usual 'gravel and water cocktail shaker treatment' to get rid of rust scale, etc.. Once the inside of the tank was sorted, work on the outside could start. A couple of small dents needed filling and sanding on the ‘After’ side, which took time to get right, as did the paint finish (once again, this was applied by brush).
Unfortunately, the pot of paint has started to get a bit old now and doesn't flow out as well, and a few bits of dust have found their way into it, so getting a good paint finish is becoming more difficult, especially on a smooth, flat surface! This is the reason I like to paint the fuel tank and any other smooth, flat surfaces first when the paint is new and fresh. I couldn't do it this time though, as it took me ages to find a suitable tank! Anyway, here’s a photo of the finished item:
Next up was the trolley. I managed to source an original Lister D barrow-type trolley from a Forum member. This trolley was ideal for what I wanted because the woodwork needed replacing as rats had gnawed large chunks out of it at some time in the past when it was stored in a barn.
Once new woodwork had been cut, the trolley was given the ‘Before and After’ treatment to match the engine. The metalwork at the handles end was sanded, rust treated and given two coats of black paint, the metalwork at the wheels end was cleaned and given a thin coat of boiled linseed oil and white spirit 50/50 mix to preserve the original finish. The woodwork was masked to match the dividing line on the engine, one side was carefully sanded and varnished, the other side was 'antiqued' to give the impression it had been there for 70 odd years.
Once the varnish and painted metalwork dried, the trolley was put back together and I had the enjoyable job of building the engine up. So this is where I'm up to; the flywheel and pulley still need to be prepared and 'half painted'. The magneto has been sorted out internally, but still needs the ‘Before and After’ external treatment to match the rest of the engine. A few nuts and bolts on the trolley need touching in, and some minor but time consuming jobs like polishing the brass fuel tap still need to be done (I hate polishing badly tarnished brass!).
So, nearly there now and hopefully on target for the 1000 Engine Rally later this month, which should be the first time out for 'Before and After'.... let’s just hope the blinking thing starts after all that time I’ve spent on it! Anyway, here’s a sneak preview of progress to date. Thanks for reading:
Jules.
thats looking brilliant, how are you doing the magneto? that will have to be half restored and half not.
looking forward to seeing with running
jules
half a job as always
coming along well now mate
see you i a week or two
Absolutely amazing you really have done a fantastic job.
Lister D 1949? ... Villiers MK25 1964 ... Villiers F15 ... Hopefully a John Deere in the future
HobbyPaul- Expert
jules thats coming along nicely , i might decide to make a trip up to astle if i can been having alot of car an van problems lately .
What a fantastic original idea - really impresed and the thread is good to follow - thanks for sharing.
best
Hamish
best
Hamish
Thanks for the comments chaps. I put the final few bits of the engine back together last Friday afternoon and took it outside for its first test run, probably the first time someone has tried to start this engine for around 40 years! So how does 'Before and After' look now it's finished?
Well, we have the ‘new’ side:
We have the old side:
And we have the bit in the middle:
But does it run? Of course it does… it’s a Lister! (click on the image to watch and scroll down to see the video, it seems to play up sometimes for some reason, so you might have to come back to it later and try again if it won’t play!):
Did it start first go? Well, almost… it fired twice then nothing. A quick check showed a healthy spark at the plug so it must be a fuel issue. I couldn’t smell much petrol from the sparkplug hole, so I removed the mixture wheel and needle, gave the needle a wipe over, and put it back. Turned it over a few times and then refitted the plug, turned the starting handle a few times and off it went.
A bit of fettling with the mixture setting once it had warmed up and it ran non-stop for the next two and a half hours before it finally ran out of petrol. It just needs a final check over and an oil change and it’s ready for the 1000 Engine Rally. Thanks for reading, and if you happen to see this engine when you’re out and about at a rally be sure to say hello.
Jules.
