Petrol tank leaks.
Petrol tank leaks.
Hi All,
I have a Lister D petrol tank that has 1 or 2 pin hole leaks in it, I was going to try and repair it using either JB Weld or Plastic padding leak fix. Has anyone tried either of these products to repair petrol leaks and if so what were the results? Is there a better product I should be using?Thanks.
Kev.
Kev.
Re: Petrol tank leaks.
I've used Petropatch, and had quite good results with it in the past
2014-02-24
2014-02-24
1945ruston- Born to be wild
Hi. Thanks for your reply -I haven't heard of Petropatch so will go and look into it- has anyone else used it and if so with what results? Kev.
Hello Kev - I've used Granville Petro Patch Putty after seeing my company use it on commercial projects - its is a hand kneadable, non-rusting, steel reinforced epoxy putty that mixes to provide permanent repair to items made of ferrous metals and aluminium which can be overpainted if required. I've had good results(zero issues) on Land rover Series 1 petrol tanks and the like that get a fair amount of abuse in off road trials after using it.
Best
Hamish
Best
Hamish
Hi Hamish - Thats a good recommendation and sounds like the product that I need.Thanks for that.
All the best,
Kev.
All the best,
Kev.
HI THERE
I may have thing you are looking for this is sold by ROBEX it's a putty type stick. If you send me your address I will send you stick and the procedure sheet that they recommend
HOPE THIS HELPS
HOPE THIS HELPS
Hi Tony,
Thanks for the offer but I have now got and used Petro Patch putty - this is easy to use,as long as you dont mix too much up at one go, and so far its done the job very well.Thanks again for your interest.
Kev.
Kev.
» Making a Petrol Tank?
» Villiers m15 rotovator petrol tank
» Shafty D petrol tank Lid
» Petrol Tank Sealers
» Help needed on Small petrol tank
