Lister D torque settings
Post by Locknut on Fri Mar 07 2014, 12:46
Hi All,
Does anyone know what the Torque settings are for the head bolts on a Lister D, and if so what are they please?Thank you.
Kev.
Locknut
Re: Lister D torque settings
Post by blackvanman on Fri Mar 07 2014, 15:05
Locknut wrote:Hi All,
Kev.
FT in steps in sequence Smile
Post by kevjhnsn on Fri Mar 07 2014, 15:58
Kev.
thought it was called "VFT"   cheers "very f-ing tight" Laughing  Laughing
hi LOCKNUT
there is no set torque setting that i know about for them and even in all the manuals and books on them just say " no set order of tightening
1st   do all finger tight
2nd  tighten them all down 2 flats on nuts ,and
3rd   repeat as requered
steel nuts in valve area
brass domed in water jacket
and add a little greese to both surfaces to allow for gasket to spread evenly while thightening ,
incase of exsenive pitting corrsion in water system gasket faces and a little gasket compound instead of greese in that area only,
 to make sure of good watertight/sealed joint
thats all the books will tell me
Post by Locknut on Sat Mar 08 2014, 13:28
Hi Guys.
Thanks for your replies.I too have checked the manual and the various You tube videos and couldn't find any answers.But following your suggestions I will first set my spanner to FT and tighten the nuts ,then go round again on a setting of VFT!
Kev - thanks for pointing out about the possible pitting in the water system gasket faces- I hadn't thought about that - so nice one!
Kev.
Locknut
Post by kevjhnsn on Sat Mar 08 2014, 14:50
dont think many people back then would of had a torque wrench to hand
like these days ,the first torque wrench i bought was cheep and on offer at £105 back in the 90s ,but today £15 will get you one
