Lister D torque settings
Hi All,
Does anyone know what the Torque settings are for the head bolts on a Lister D, and if so what are they please?Thank you.
Kev.
Kev.
Re: Lister D torque settings
Locknut wrote:Hi All,
Kev.
FT in steps in sequence
blackvanman- Life Member
blackvanmanblackvanman wrote:Locknut wrote:Hi All,
Kev.
thought it was called "VFT" "very f-ing tight"
hi LOCKNUT
there is no set torque setting that i know about for them and even in all the manuals and books on them just say " no set order of tightening
1st do all finger tight
2nd tighten them all down 2 flats on nuts ,and
3rd repeat as requered
steel nuts in valve area
brass domed in water jacket
and add a little greese to both surfaces to allow for gasket to spread evenly while thightening ,
incase of exsenive pitting corrsion in water system gasket faces and a little gasket compound instead of greese in that area only,
to make sure of good watertight/sealed joint
thats all the books will tell me
Hi Guys.
Thanks for your replies.I too have checked the manual and the various You tube videos and couldn't find any answers.But following your suggestions I will first set my spanner to FT and tighten the nuts ,then go round again on a setting of VFT!
Kev - thanks for pointing out about the possible pitting in the water system gasket faces- I hadn't thought about that - so nice one!
Kev.
Kev.
dont think many people back then would of had a torque wrench to hand
like these days ,the first torque wrench i bought was cheep and on offer at £105 back in the 90s ,but today £15 will get you one
» villiers c25 torque settings
» JAP Model 2 A head bolt torque settings
» Lister d valve settings?
» Lister B carb settings
» Lister CS 6/1 injector/pump settings
