H2 Restoration.
H2 Restoration.
Post by steamman on Tue Mar 11 2014, 14:52
Hi, could somebody tell me if there is a book on the market on how to restore a Lister H2 pump, I have started to dismantle mine but have run into a problem with removing the valve caps on top of the pump the ones with the large hexagon on them, I have tried Plusgas and a large wrench to no avail, I don't want to damage them. I would be grateful for any help.
Thanks, Bernard.
steamman
Re: H2 Restoration.
Post by matt86 on Tue Mar 11 2014, 20:31
steamman wrote:Hi, could somebody tell me if there is a book on the market on how to restore a Lister H2 pump, I have started to dismantle mine but have run into a problem with removing the valve caps on top of the pump the ones with the large hexagon on them, I have tried Plusgas and a large wrench to no avail, I don't want to damage them. I would be grateful for any help.
Thanks, Bernard.
there isnt a book on how to do it but is a book on lister shallow and deep well pumps but thats a sales book rather than repair . Think Villiers or foden on here would know how to get them out .
Re: H2 Restoration.
Post by billypurves on Tue Mar 11 2014, 21:24
Hi Bernard, Do you have the brass plugs with the square hollow centres? If so . you can make up a tool from square bar that you can use to unscrew the plugs......safer than using the hex s as they can tear off. These can be very tight!! Billy.
billypurves
Re: H2 Restoration.
Post by matt86 on Tue Mar 11 2014, 21:33
i thought he was on about the valves under the plugs billy ?
1" square bar fits with a girt pair of stilsons !
Re: H2 Restoration.
Post by steamman on Tue Mar 11 2014, 22:07
The caps I have got haven't got the square hollow centres they have got large hexagons.
Thanks, Bernard.
steamman
Re: H2 Restoration.
Post by matt86 on Tue Mar 11 2014, 22:08
steamman wrote:The caps I have got haven't got the square hollow centres they have got large hexagons.
Thanks, Bernard.
a fooking big spanner then !
Re: H2 Restoration.
Post by billypurves on Thu Mar 13 2014, 21:58
Bernard, All I can suggest is heat the casti ngs around the brass caps and with a tight fitting spanner unscrew them.
These are seldom easy to remove, but with patience.
billypurves
Re: H2 Restoration.
