bradford drag saw
bradford drag saw
Post by autograss on Thu Mar 13 2014, 07:56
hi i am in the process of rebuilding a bradford engine off a avon drag saw can any body tell me if it needs a head gasket also the tappet clearance and touqre settings thanks in advance
autograss
I really need to post more
Re: bradford drag saw
Post by matt86 on Thu Mar 13 2014, 09:39
Yes you will need a head gasket, I make mine using a material called klingersil which you get get of eBay. Use a hole/leather punches to cut holes in in.
Torque setting, I never bother as many of these old engines have no info listed for torque figures. Just do all up finger tight and nip up with a ratchet then a small breaker bar doing up opposite side at a time but don't over do it just so it's nice and snug. Once been run tighten a touch more.
Post by mike d on Thu Mar 13 2014, 17:24
ya works for me as well..
Post by autograss on Thu Mar 13 2014, 19:43
thanks for the info
autograss
