Lister A advice
Lister A advice
I am now starting to put my engine together and am stuck already. I have a new paper gasket set but I am unsure if is right.
When I tighten the main bearing housing the crank shaft is very hard to turn, loosen housing of and I can move crank shaft easy.
I believe I just need to make a thicker gasket, are my thoughts correct or am I over looking something/
Rodit
Rodit
Rodit- Born to be wild
Re: Lister A advice
if thats what you need to do make a gasket and see how it goes ,
Re: Lister A advice
You need a thicker gasket.
» Lister Engine - Any Advice?
» Initial advice for a Lister Domestic Water Pump
» Anyone having Lister SR1 Workshop Manual?
» Petter A1 Advice please
» After the Forums Advice
