Lister A advice
Lister A advice
Post by Rodit on Sat Mar 22 2014, 21:19
I am now starting to put my engine together and am stuck already. I have a new paper gasket set but I am unsure if is right.
When I tighten the main bearing housing the crank shaft is very hard to turn, loosen housing of and I can move crank shaft easy.
I believe I just need to make a thicker gasket, are my thoughts correct or am I over looking something/
Rodit
Rodit
Re: Lister A advice
Post by matt86 on Sat Mar 22 2014, 22:10
if thats what you need to do make a gasket and see how it goes ,
Re: Lister A advice
Post by Villiers on Sun Mar 23 2014, 09:05
You need a thicker gasket.
Re: Lister A advice
