Godwin water pump
Godwin water pump
Post by Locknut on Tue Mar 25 2014, 19:46
Hi All,
This is my latest project :-
It is a Godwin A1E water pump. I know nothing about this pump,does anyone know if there is a manual for this pump and if so where I can get one from?
One ( the left) ,the input( photo 3), of the cylinders( not sure what the correct name for it is!) has been replaced with a welded pipe set up - does anyone know where I can get an original replacement from? Also can anyone let me know which way the pulley wheel is supposed to rotate - clockwise( looking straight at it as photo 2)?
And finally how can I get a date for it?( It does have a number!)
Any help or advice would be much appreciated.Thanks.
Kev.
Locknut
Re: Godwin water pump
Post by kevjhnsn on Tue Mar 25 2014, 22:40
hi kev
i also have a1e but i dont even have the diy accumilature ,its to take the spike load out the plumbing every time the pump pushes the water out
i also have a shout out for a second accumilature
maybe if we both look out for a complete nackered doner with the 2 on it we could split the cost of unit and then resell the remains on and split that or the likes just an idea, if you like let me know
thanks kev
Post by Locknut on Wed Mar 26 2014, 08:59
Hi Kev,
Ah - I wondered what it did!Your idea sounds a great one,and what with the rally season and auto jumbles about to start we might just be lucky!
Funnily enough I will be in Cheshire ( Stockport area) in the next month or so, so if we have a donor by then we could perhaps meet up.Kev.
Locknut
Post by kevjhnsn on Wed Mar 26 2014, 22:45
Locknut wrote:Hi Kev,
sounds good to me
lets get digging
Post by mike d on Wed Mar 26 2014, 23:11
ive got one as well, must get it sorted and painted, ready to sell..
Post by kevjhnsn on Wed Mar 26 2014, 23:50
mike d wrote:ive got one as well, must get it sorted and painted, ready to sell..
mr d
how much as it stands £££
and has it 2 x accumilators fitted ??
Post by Locknut on Thu Mar 27 2014, 08:25
Hi Kev,
My delivery accumilator is ok, it is the input/suction one that I need to replace.Are they interchangeable because on my pump it does'nt look as if they are?Which one are you after?
Kev.
Locknut
Post by Matth92 on Thu Apr 03 2014, 20:24
One of the ones on my one I had was broken off around the flange, i just shaped a nice thick steel plate and put a 3/4 BSP thread through it
Post by mike d on Thu Apr 03 2014, 20:34
mr d
yes kev it has the 2..
make me a sensible offer on it
im selling 4 pumps and two 3hp open crank engines,,
or i will consider swapping an engine for a 1 1/2hp open crank..
the engines will be posted in the for sale section tomorrow (friday4th April)
