lister d very loud
lister d very loud
Post by marknva on Tue Mar 25 2014, 21:23
I know this seems daft. after seeing lister d's running and seeing them on youtube they all seem within reason pretty quite but mine seems pretty loud on tick over and under load. Is it just my lister or is there something wrong
cheers mark
marknva
Re: lister d very loud
Post by Lewis MacRae on Tue Mar 25 2014, 21:31
Does it have a wide exhaust or a Thin one, my one had a thin one but it was also loud, so I switch it for a Wide one.
Post by marknva on Tue Mar 25 2014, 21:50
About 1" pipe and then a pancake end about 6" round
marknva
Post by Lewis MacRae on Tue Mar 25 2014, 22:00
Hi mate ment in width
Post by marknva on Tue Mar 25 2014, 22:04
Lewis I wish I could post a pic but on my phone but there is a pic of the exhaust on herehttp://www.stationaryengineforum.net/t7975-my-new-bamford-and-lister
marknva
Post by Villiers on Tue Mar 25 2014, 22:57
Timing is out, needs resetting.
Post by kevjhnsn on Tue Mar 25 2014, 22:57
here you are pasted the pic across for you mate
http://i57.servimg.com/u/f57/18/77/26/06/17819411.jpg
that looks to be the correct exhurst system for the 1930s to 1960s lister d specs
sounding like the spark is to late to me ,so recheaque your timing mate
thanks kev
Post by marknva on Tue Mar 25 2014, 22:59
How do I go about re setting the timing
marknva
Post by Villiers on Tue Mar 25 2014, 23:03
Find the lightning flash on the flywheel, put this at the top, undo the points cover and then slacken the bottom sprocket nut, pop that sprocket off, turn the mag in the right direction until the points just open, tighten the nut and bingo.
Post by marknva on Tue Mar 25 2014, 23:07
Where am I going to be looking for the flash on the fly wheel top side etc
marknva
Post by kevjhnsn on Tue Mar 25 2014, 23:13
marknva wrote:How do I go about re setting the timing
there should be a spark/lightening strike on the flywheel ,remove the rocker cover and rotate until the 2 camshaft arms/rockers are both free of pressure with a little gap as in the setting of the valve gaps
and the flywheel should be with make at top dead center of vertical engine
and then remove the cover off your magneto
and lossen slide bolts from under side of mag ,then in direction of engine  rotation turn the mag  to thepoint were the points should just be wide open or just starting to open slightly
depending in wear on chain ,other way if pulley on mag will come frre ,is loosen the pulley center nut pop pulley loose and then rotate mag from flat screwdriver slot in points end of mag center shaft
Post by kevjhnsn on Tue Mar 25 2014, 23:14
i need to type faster tonight mr villiers lol Laughing  Laughing
Post by callum12 on Wed Mar 26 2014, 00:11
don't forget though, cameras can lie, especially microphones, built-in mics don't replicate sound volume very well. yours might not be that loud, but still redo valve timing.
callum12
Post by Villiers on Wed Mar 26 2014, 07:52
[quote="marknva"]Where am I going to be looking for the flash on the fly wheel top side etc [/quote]
On the face. Not wishing to sound rude but get out and look.
Post by marknva on Wed Mar 26 2014, 08:04
Well I was tucked up in bed when asking lol
marknva
Post by marknva on Thu Mar 27 2014, 09:03
All sorted yep the timing was miles out runs a lot better now and abit quiter thanks guys
mark
marknva
