Pegson Marlow Pump and B&S 3HP
I have recently purchased a 1960 Pegson Marlow 1.1/2" Pump mated to 3HP B&S Engine.
I have attempted to separate the pump from the motor but, am stuck not knowing if the nut holding the impeller onto the crank is LH or RH thread. (Logic would suggest LH but, as the flywheel nut is LH thread I am wondering if the impeller nut is RH)
Any help would be appreciated.
Sidevalve@44- I really need to post more
Re: Pegson Marlow Pump and B&S 3HP
I would go for RH thread Myself, the Pegsons coupled to Villiers and Jap engines are at least.
Thank you. I think I will start with RH. Guess I'll have to get a puller made up to pull it off the crank once I've got the nut off.
» Pegson Marlow Impeller removal
» J.A.P. with Pegson pump
» Pump ID please
» Found Something For The Amanco To Run
» Jap 2A with pump
» Pump ID please
» Jap 2A with pump
