Carb Float + needle assembly
Post by gerrybongo on Tue Apr 08 2014, 23:50
I assume that you put the needle through the base of the float bowl , then locate the float onto the needle until the float clip fits in the groove , Question how does the float not fill with fuel and sink and allowing the fuel to flood the bowl , because they have to be a loose fit or how could you assemble in that way . I can only guess that when you run dry to stop the engine it empties the float , it obviously works as they have done for years , or is the one i have had in bits and assembled not correct in some way .
gerrybongo
Re: Carb Float + needle assembly
Post by Foden on Wed Apr 09 2014, 10:50
The float is sealed with solder so shouldn't contain any fuel, if it sinks then you have a leak (you will here fluid if you shake the float) which can be found by immersing it in water and watching for bubbles.
Post by gerrybongo on Wed Apr 16 2014, 22:19
I can see the solder and understand the theory of how it seals , But it can't be an airtight fit or you could not pull the needle through .  confused
gerrybongo
Post by Villiers on Thu Apr 17 2014, 07:09
Oh yes it is...
There is a small tube in the middle of the float that the needle goes through, this is soldered to the float at both ends.
