How / Is it possible to date a Lister D from the casting numbers?
Post by H.Y on Fri May 09 2014, 01:33
Hello,
I am new to this site, first post.
I have two Lister D's one of which is missing the brass identification plate is it possible to date and determine the engine output from the casting numbers?  The upper cast number is 19F1  1 1062 and the lower number DS602 and jj1.  I would be grateful of any advise as I have four engines to sell and I am sure enthusiasts would want more information on the Lister's than I can currently provide.
H.Y
Re: How / Is it possible to date a Lister D from the casting numbers?
Post by Lewis MacRae on Fri May 09 2014, 06:52
the serial number should be stamped on the crown of the flywheel...
Lewis [You must be registered and logged in to see this image.] , x2 Lister D, x1 IHC LAA, x1 Lister L, x1 Wolseley WDII, x1 Amanco Chore Boy, x1 Fairbanks Morse Z 3 HP, x1 Crossley 1030?
