V-pulley's
V-pulley's
Post by gerrybongo on Fri May 09 2014, 16:18
Hi can anyone give me a little advise on a twin V pulley i have , It has a key way but no locking screw , is this the same as fitting a flywheel + gib key . not that i have yet fitted a flywheel but if it is the way to go i will fit , although im just concerned the key is not locked . thanks
gerrybongo
Re: V-pulley's
Post by matt86 on Fri May 09 2014, 17:14
if its a gib key it relies on a tapper to keep tight on the shaft so as you drive the gib key in which has a angle on it locks the pulley on .
Re: V-pulley's
Post by gerrybongo on Mon May 12 2014, 21:23
Thanks , yes its a key but not like the flywheel key , it was just that all the pulleys i have seen had a locking bolt on the pulley
gerrybongo
Re: V-pulley's
