Any Clues??
Any Clues??
Post by Polybus on Thu May 15 2014, 08:40
G'day!!
Picked up another old kick/pedal start engine today.
No sign of any identifying marks/brands/numbers anywhere - but maybe something will turn up when I give it a clean.
I can't tell you anything about it other than the guy I got it off said he thinks his dad has had it stashed in his shed since the 50's - and I'm in Australia, so perhaps its an Aussie made something or other.
Full set of photos here.....
s941.photobucket.com/user/g_barrington/slideshow/Stationary%20Engines/Unknown%20Pedal%20Start
(Just cut and paste the above address into your web browser to see the photos)
Love to hear your suggestions
Polybus
Polybus
Re: Any Clues??
Post by blue cat on Thu May 15 2014, 18:38
Looks Like a Briggs & Stratton engine to me.
Possibly a type Z or type ZZ.
Its missing the cooling cowl in the pictures.
Re: Any Clues??
Post by Foden on Thu May 15 2014, 21:42
Tried the link and just get 'unavailable' on here.
Re: Any Clues??
Post by matt86 on Thu May 15 2014, 22:41
worked for me
Re: Any Clues??
Post by Polybus on Fri May 16 2014, 00:16
I've had a few votes for Briggs and Stratton - but many disagree on the mode - one guy suggested a Model A, and I accept your suggestion of a Z or ZZ with thanks Smile
I will do a bit of homework and try and dig up some photos of al three the A, the Z and the ZZ and see what I can come up with.
And yes - it does look like the cowl is missing - I seem to be missing cowls on most of my engines - so if anyone knows where I can get a cowl for this engine, or one for a J.A.P.Model 6 - I'd love to hear.....
Thanks so much for your help Smile
I'll post again when I come up with anything more.
Polybus
Polybus
Re: Any Clues??
Post by Foden on Fri May 16 2014, 13:43
Ah, Matt's link works!  It is a Briggs Model A the same as my old one which I recently restored and sold.  Clues are that the front main bearing plate is not detachable and I bet the carb has no choke butterfly as they had a remote inlet tube and air cleaner with the choke butterfly incorporated.  Kick start A's are quite rare even in the USA, mine had no drillings in the crankcase for a fuel tank bracket as a lot were fitted inside Army Tanks and ran off of the tanks main fuel supply.  Mine had JAP 2A tank fitted!
Before.
After.
Last edited by Foden on Fri May 16 2014, 22:33; edited 1 time in total (Reason for editing : Adding link to Briggs site.)
Re: Any Clues??
Post by Polybus on Sat May 17 2014, 06:42
Where is the Engine Number located??
I have had a quick look but haven't been able to find it. It pretty dirty though, maybe I just need to clean the right area Smile
Polybus
Polybus
Re: Any Clues??
Post by Foden on Sat May 17 2014, 07:10
polybus wrote:Where is the Engine Number located??
Polybus
Alas the only numbers on a Briggs are on the shroud that is missing on yours, the tag can be seen in the pic below of my old Model I that I used to own.  Yours is an A though, if the cylinder head is alloy then it will be an AL.  The Model B is about half as big again as an A, and the Z and ZZ are huge and have removable cylinder barrels.  There is normally a date code on the magneto backplate which can only be seen when dismantled, I would date yours as a WW2 period engine probably ex Military.
Another Clue.....
Post by Polybus on Sun May 18 2014, 00:03
Thanks for all of your input so far - I like the idea of it being a WWII ex-military engine - I can see it painted up in Olive Green already Smile
Real bummer - without the cowl/engine cover, I've got no hope of really getting to the bottom of it I guess.
One further clue - I haven't been able to get a look at the back of the magneto but I did find this little plate on the bottom of the crank case.
Its a little screw on plate with two tiny screws, one at each end. It's only about 3/4 inch long, and bears the numbers "13-0" and that's it - see the photo.
Does this give anyone any more clues?
[You must be registered and logged in to see this image.][You must be registered and logged in to see this image.]" />
Polybus
Polybus
Re: Any Clues??
Post by blue cat on Sun May 18 2014, 18:27
Yes, that's a casting number for that part of the engine. No help in dating I'm afraid.
Re: Any Clues??
