lister generator
lister generator
Hi all a friend and I are restoring a lister type "A" lighting plant and would like to find out the year model etc ,Here is what is on the plates.
PLANT NO 35848 NA
ENGINE NO 222A2
GENERATOR NO 50C5036 SIZE 1.5 KW
HP 3 600 RPM
LISTER
AUTO CUT IN ANDOUT
PAT NO 35166
--- AMPS 32 VOLTS
SERIAL NO 6907/ SPEC NO J
LISTER SWITCH BOARD
TYPE CTV
NO 17339
RA LISTER
DURSLEY, ENGLAND
TYPESHUNT S/S COMP D
VOLTS 32/43
AMPS 40
SPEED 1950
Cheers malcolm
PLANT NO 35848 NA
ENGINE NO 222A2
HP 3 600 RPM
LISTER
AUTO CUT IN ANDOUT
PAT NO 35166
--- AMPS 32 VOLTS
LISTER SWITCH BOARD
TYPE CTV
NO 17339
RA LISTER
DURSLEY, ENGLAND
VOLTS 32/43
AMPS 40
SPEED 1950
Cheers malcolm
malshel- Posts : 1
» Lister Generator
» Lister D and generator
» Suitable generator for Lister D
» lister jp 4 generator 1939
» Lister HA2 Generator in Angus :D
