fairbanks headless winter project
+5
9 posters
Page 1 of 6
Page 1 of 6 • 1, 2, 3, 4, 5, 6
Its funny how one minute you have a engine sat in the shed like this
then at around 10.00 i popped into the shed to tidy things up and lock up and stood there pondering as you do next thing 20 minutes later you end up with this
not many parts to this engine at all , all i can do now is to remove the flywheels and give the block and other parts a good clean with degreaser . and then i get get rubbing the paint down !
Re: fairbanks headless winter project
WHAT HAVE YOU DONE TO IT? LOL
But saying that it does look good, thought this was a winter project cause if you carry on at this rate it will be done end of October. Y ou say, rub the paint down, wouldent it be better to strip paint to bare metal ?
watch you dont loose the box with the cylinder head in while doing her up mate:D
what a lovly simply design,
happy cleaning and sanding
he probable will wen he gets stuck in ,as we all say a quick sand down and end up like thisLewis MacRae wrote:WHAT HAVE YOU DONE TO IT? LOL
oh balls have i lost it already ?!kevjhnsn wrote:matt
better get another from hit and miss then
giving it a birthday !Lewis MacRae wrote:WHAT HAVE YOU DONE TO IT? LOL
i think all other bits will be taken down to bare metal but the block is so smooth and the paint is so hard i will give it a clean , and get the scotchbrite on it then some 800 or 1000 wet and dry and give it a rub over .
Yep, do you have the
Paint for it?
Paint for it?
not yet
In the week i will nip into screwfix and get some red oxide as the stuff i have here is terrible like spreading jam on a brush ! and drys with brush marks ... never buy tractol paint !
now im thinking on the colour as spoken to 2 paint mixers and gave them a dupont code which is a american paint code and they can not match it , so i guess im going to have to go buy eye ....
looking at abes's fairbanks that chris painted .
http://www.stationaryengineforum.net/t7473-new-toy-great
and been looking on the craftmasters website i think this is best match .....
http://www.craftmasterpaints.co.uk/colours-standard-range.htm its the classic green
and do i paint the conrod and balance weights on the crank green too or go for black ? As normal all moving parts will be wire brushed and polished up same with the nuts and bolts , split pins will be replaced for new too .
I say to for black as it looks nicer, I think but it's your engine your choice!
I have an idea, Ask chris were he got his paint!
Im sure he will be along somepoint ....
in that case ...
Chris , would you have a paint code for this engine which matches for a uk colour code ?
Thanks , matt
in that case ...
Thanks , matt
spent a couple of hours in the shed today cleaning and rubbing down the block .
rubbed down and masked up ready for the high build primer or red oxide have not decided which yet ...
Not sure how to mask this hole up and i have got the intention spraying the block
Had a quick look at the crank and main journals , all seem ok .
left side
right side
crank , this is the worst so might see if i can clean it up with some extremely fine wet and dry or scotchbrite
Took the axles off the trolley , cant believe some people how they fabricate axles at times .... Or is this a that will do job ....
left side
right side
No need for a primer if you rub down Matt, just 1 of undercoat and a couple of top coats
you never know what might happen when i apply a undercoat ? as the paint might react with the older paint underneath will will see what happens . If that happens i will have to get the paint stripper out
Should be fine, oil based paint on oil based paint and all that, even a primer will react with the wrong paint.
Looking good, what masking tape is that , blue?
Got the can of paint Chris used in the back of the van mate, but know he had it mixed so not sure if it will have any code on it
matt86 wrote:Im sure he will be along somepoint ....
in that case ...
Thanks , matt
If you have the code that will be great for matt and myself!Abes wrote:Got the can of paint Chris used in the back of the van mate, but know he had it mixed so not sure if it will have any code on itmatt86 wrote:Im sure he will be along somepoint ....
in that case ...
Thanks , matt
Yes its blue , its a low tack stuff i think its 3m tape , left over when did some body work on my old van .Lewis MacRae wrote:Looking good, what masking tape is that , blue?
Abes could you do me a favor ? on a scrap piece of wood or ideally steel paint a little bit with red oxide and once gone off paint with a coat or 2 of the green . When i come down i can take it away and get it matched somewhere .Abes wrote:Got the can of paint Chris used in the back of the van mate, but know he had it mixed so not sure if it will have any code on itmatt86 wrote:Im sure he will be along somepoint ....
in that case ...
Thanks , matt
Cheers , matt
Ill see what I can do mate
matt86 wrote:Abes could you do me a favor ? on a scrap piece of wood or ideally steel paint a little bit with red oxide and once gone off paint with a coat or 2 of the green . When i come down i can take it away and get it matched somewhere .Abes wrote:Got the can of paint Chris used in the back of the van mate, but know he had it mixed so not sure if it will have any code on itmatt86 wrote:Im sure he will be along somepoint ....
in that case ...
Thanks , matt
Cheers , matt
thought to myself i should get the bare metal bits with some red oxide , so had a look around and found some old red oxide that last used 3 years ago and it was a nearly new tin and tell you what .... it paint lovley not too thick like other rubbish i have found .
next thing after painting the are patches i nearly covered the whole block then sod it il paint it all ...
even moved to the other shed which is insulated and i can work on the other bits and not get crap over the block .
Cheers would be helpfulAbes wrote:Ill see what I can do matematt86 wrote:Abes could you do me a favor ? on a scrap piece of wood or ideally steel paint a little bit with red oxide and once gone off paint with a coat or 2 of the green . When i come down i can take it away and get it matched somewhere .Abes wrote:Got the can of paint Chris used in the back of the van mate, but know he had it mixed so not sure if it will have any code on itmatt86 wrote:Im sure he will be along somepoint ....
in that case ...
Thanks , matt
Cheers , matt
No probs mate engine is looking good too told you you would end up doing it lol
» a winter project....
» my winter project
» my new project for the winter
» This is my new project for the winter
» Winter Project
» my winter project
» Winter Project
Page 1 of 6
