WICO A impulse tripping before mags points close
Well I've been scratching my head for days on this one and finally realised I am not going to work this out on my own,
I have a WD2 anticlockwise rotation, I fitted what I believed to be an appropriate Wico A (the trip works in the direction I need it to) on an appropriate bracket. Timed the impulse to trip AT TDC as per the WD2 I owned twenty years ago, but no joy.
When I look at the points the impulse trips at TDC but the points don't close until about 100 degrees AFTER TDC!
I am clearly missing something vital here and it is driving me bloody crackers, as I can't see how this could be occurring as everything seems to have a clear and definite position on the mag with no 'little' variances indeed it seems I could only fit everything 180 degrees out.
As I say I just cannot see what is not correct to cause this and I am now considering going to the corner for a cry or the pub for a couple of gallons of scrumpy.
MAT ~:0$
MAT ~:0$
paraffinmat- I really need to post more
Re: WICO A impulse tripping before mags points close
Have you seen this site http://www.oldengine.org/members/diesel/Magnetos/MagData4.htm
On it there are pages with listings of the various parts fitted to make various types of magneto for each application.
We are trying to make 4 cylinder mags out of singles and I see there are quite a few different types of points cams and different types of impulse mechanisms so I wonder if the mag you have may have an invalid combination.
Long shot and/or maybe you have already checked this, but sounds like something like this.
In the IHC mags service book there is also quite a section on overhauling WICO mags.
Well worth looking at if you haven't already found it
Darryl
N.Z.
Darryl
N.Z.
Darryl Ovens- Expert
P.S. Spark occurs when points open, not close in case that is significant.
Thanks Darryl, it was significant as I had fitted the impulse exactly 180 degrees out. Now put on the right way round and sparking like a tart in nylon sheets.
» wico mags oiling
» Wico magneto - points cover
» Wico A points covers (Free at Tescos)
» low tension mags
» Wipac Impulse Magneto.
» low tension mags
