Info on the mixing of TVO?
Hello
Have not long bought my Ruston Hornsby and have run it on the TVO that came with it when I bought the engine, I now need to mix some more TVO I know it's a mix of petrol and 28 second heating oil, but can some one tell me the correct ratio please
Best Regards Dave
Best Regards Dave
flogalog- Born to be wild
Re: Info on the mixing of TVO?
By rights now you need a licence to mix TVO but your engine, what is it?AP? PB? Will run on 28sec heating oil without mixing. These engines are designed to run on Paraffin, not TVO, the clue is in the name, TRACTOR vaporizing oil, if you find it doesn't run that well on 28 sec then add a little petrol till it does. If it is a PB (3hp and above) then change the oil regular.
Hello Villiers
Sorry I forgot to mention it is an AP 5 &half HP
Best Regards Dave
Best Regards Dave
Should run on 28sec easy enough, brother runs his 6AP on it no problem.
» Spark Plug alternative
» BSA info anyone?
» need info on this one....
» Dynamo Help
» Keith from Cornwall
» BSA info anyone?
» Dynamo Help
