wolseley oil
wolseley oil
Post by RAB on Sun Oct 25 2009, 00:20
i use sae30 in my other petrol engines, but as this WLB1 is 3 3/4 hp should i use something a bit better so the beast dont dehidrhate cheers
Re: wolseley oil
Post by JONESEY on Sun Oct 25 2009, 09:44
No it would only ever run on cheap oil.
I always use Morrisons oils they do a range for Vintage Engines and Steam
will morris vintage motor oil sae30 be ok
Post by RAB on Tue Oct 27 2009, 19:38
will morris vintage motor oil sae30 be ok , £15 for 5 litres
Re: wolseley oil
Post by JONESEY on Tue Oct 27 2009, 22:15
Thats all I use its great stuff, I buy all my Degreasers,penatrating oils ect from them they deliver to my door .
Just had a delivery today Laughing
Chris Very Happy
Re: wolseley oil
Post by Avandriver on Thu Oct 29 2009, 01:21
FIFTEEN QUID !!! for five litres
You must be mad .
Get down to Asda
£3.99p for five litres Asda motor oil
Change it every season and you will have no problems
Steve
Avandriver
Re: wolseley oil
Post by Guest on Thu Oct 29 2009, 07:36
Avandriver wrote:FIFTEEN QUID !!! for five litres
You must be mad .
Get down to Asda
Steve
and as well as that steve, the asda's oil owing to its low price, is unlikely to contain the fancy detergent stuff for modern high performance engines, which means its rather good for our old engines.
Paul santa (its coming)
i just didnt know
Post by RAB on Thu Oct 29 2009, 12:11
if it had to be something differant as the HP was more, thanks chaps, ill get it sorted cheers
Re: wolseley oil
Post by Guest on Thu Oct 29 2009, 12:30
ryan wrote:if it had to be something differant as the HP was more, thanks chaps, ill get it sorted cheers
ah not really ryan, consider your engine to be around 500cc (which it isnt but its a good guess) and it puts out 3hp or so, now imagine that engine as a 2.0 litre, 4 cylinder engine, thats 12hp, compared to the 120hp that about the minimum expected of a 2.0litre car engine now, and it gives you some idea of what conditions our oil puts up with compared to a car engine, that also incidentally runs 5-10times faster too.
Paul afro one cool stationary engine dude
cheers paul
Post by RAB on Thu Oct 29 2009, 14:14
i have a better understanding now cheers
Re: wolseley oil
Post by JONESEY on Thu Oct 29 2009, 22:39
Everybody to there own style and make of oil
i got to admit i probely will go for the morris SAE30
Post by RAB on Fri Oct 30 2009, 04:02
i used SAE30 in many engines and its always been proven to be good, may try the supermarket oil, in a spare engine i have, thanks for all the advice though Very Happy
Re: wolseley oil
Post by Hope and Crank on Sat Oct 31 2009, 18:03
Sounds like your mind is made up, but FWIW I always use Morris SAE30, yeah it's not cheap, but it comes in metal tins - looks the part!!! Laughing
Hope and Crank
this one was in navy blue plastic container
Post by RAB on Sat Oct 31 2009, 18:06
said morris sae30 on front, is that not it lol
Re: wolseley oil
Post by Hope and Crank on Sat Oct 31 2009, 18:12
Probably exactly the same, just I'm foolish enough to pay extra for the tin!!!
Hope and Crank
using this now seems good oil
Post by RAB on Tue Dec 08 2009, 18:00
Re: wolseley oil
