Help float and carb on lister d
Post by Micbry89 on Fri Jun 20 2014, 19:02
On my lister d it running but fuel spitting out top of float a lot and the hole below the choke pin on side of carb is leaking petrol I  tried clean carb and float but at a reel lost here guys and gals help plz  confused
Micbry89
Re: Help float and carb on lister d
Post by Aron830 on Wed Jun 25 2014, 21:01
Is the float ok? When mine did that the float was stuck, I hit it with a spanner and it stopped.
Aron830
I really need to post more
Post by callum12 on Fri Jun 27 2014, 22:23
take out the rod that the float is attached to and give the tapered bit at the bottom a clean. this bit works as a valve, if there is grit in it or its corroded it will not mate with the tapered hole and stop the flow of fuel.
failing that, try adjusting the float height, there should be a little grove that the float clip fits into.
the first problem happened to me at a rally, its a two minute fix.
hope this helps,
callum
callum12
Post by blue cat on Sat Jun 28 2014, 11:11
Aron830 wrote:Is the float ok? When mine did that the float was stuck, I hit it with a spanner and it stopped.
Hitting floats with spanners is definitely not a practice to be recommended  No
blue cat  cat
Post by callum12 on Thu Jul 03 2014, 22:47
iagree
hitting the float with anything doesn't sound good, their made of thin copper and a really thin brass rod. all you should have to do is push it down with your fingers if it is stuck
callum12
