Lister CD cam arm clearance
Page 1 of 1 • Share •
Hi every one ,does anyone know how to get the correct clearance [.5 - .75 mm ] between the camshaft operated rocker arm cam follower and the underside [bucket bottom] of the injector pump on a Lister CD,with the pump bolted down it seems as though there is a constant pressure on the underside of the pump by the arm, there is an adjustment screw on the end of the arm, but I am reluctant to alter this setting,I understand this clearance is to compensate for any manufacturing discrepancies ,Any knowledge or information would be much appreciated . Thank you in anticipation. Michael.
michael- I really need to post more
» parts list for mods on engine from stw
» WTB TD .09 RC Carb
» Timing problems
» Timber type and size for a Lister D ?
» Timing problems
