Hartop H information, history required.
Could somebody tell me a little about these engines or point me to some information, I might be restoring one but need to find out if it is worth restoring.
Thanks Noel
Thanks Noel
NoelA- Born to be wild
Re: Hartop H information, history required.
most engines are worth restoring these hardtops can fetch a few £100 ask matt h he has one on here .
H type Hartop
I have just restored an H type and a M type. The H type was quite well made all be it of poor design but the M type was badly designed and badly made. I have never come across an engine built with the studs a size under the holes they fit through and no locating flanges on the rear cover, governor housing or cylinder block. You just flop it all around on the big clearances till it all lines up and bolt it up, very poor. Most of the studs are 5/16'' and the holes are 3/8''. Still I suppose that's why they where only £8.00 when new.
Gaudin98- Expert
» Hartop M type
» capel looking for history
» Lister A16 help required
» Bamford history
» Blake Waterpumps (info required please)
» Bamford history
