Small Honda Generator, Tapered shaft question
I am working on a Honda EX1000 Generator and am at the stage of reinstalling the rotor onto the tapered shaft.
There is no keyway just a tapered shaft with a long throughbolt.
My question is:
Should I heat the rotor prior to installing so that it will be a little tighter on the crank or do you think the pressure of the throughbolt will be enough to hold the rotor from spinning on the crank?
Thanks in Advance
My question is:
Thanks in Advance
Uncledeadly- Posts : 1
Re: Small Honda Generator, Tapered shaft question
All the ones I have repaired for customers in days gone by have been OK with pressure of the throughbolt
All the Best and Good Luck Tony
Plus if you heat it before assembly it will go on tighter, but you wont be able to heat it to get it off, so you or the next person will have a devil's own job to shift it. They can be hard enough to shift as it is.
Just make sure both mating surfaces of the taper are really clean, (ie wash it with solvent to remove any oil), and there are no dings or burs. If the tapers are the same angle you will find it locks solid.
Darryl Ovens- Expert
» Modern generator tapered shaft problem.
» Petter A1 by first time restorer
» Engine shaft Guards.
» Shaft Size
» Having a few problems
» Shaft Size
