Viilers engine identification
Post by Woodsman on Thu Oct 02 2014, 08:16
Yes, I know this is a Stationary engine forum - just ignore the wheels OK?
From a bit of surfing I believe this is a Villiers MK11. Can anyone confirm?. Any hints, tips, look out for, gotchas, manuals to aid renovation gratefully received.
Re: Viilers engine identification
Post by kevjhnsn on Fri Oct 03 2014, 01:18
its a villiers 11C 2 stroke ,
fitted to the remains of a  allen sythe , F model of allen or oxford allen sythe,going off the daylight coming through the wheel and shape of wheel center , as the TS model, were solid centered  wheel and one continues curve.
tyre size is usually  2.75 x 21
Post by Woodsman on Fri Oct 03 2014, 12:16
Hi Kev. Brilliant as usual. Manual seems a little hard to find though. Have tried most of the usual web sites without success.
Post by Woodsman on Sat Oct 04 2014, 11:01
Hi Kev,
Are you sure about Model F - I was thinking T?
Post by kevjhnsn on Sun Oct 05 2014, 00:20
thinking i was wrong to also from the new picture,
as the F has a 2x square bar  and the TS has the one flat plate down to cutter bar  Embarassed
will have a root and see if i have a manual for the 11c
Post by Woodsman on Mon Oct 13 2014, 10:47
Top man. Thanks Kev.
