Villiers MK10 - How to remove valves to re-grind
OK ,so I've removed the carburettor and the valve cover plate. I can see the valves and springs but how on earth do I get a valve spring compressor in there so that I can remove the collets? Is there some special tool I need or I am missing something ?
Re: Villiers MK10 - How to remove valves to re-grind
Ah - turns out the springs are not as strong as I thought - a piece of flat bar with a slot in and an extra pair of hands does the trick.
» Viiliers MK10 - How to remove magneto flywheel
» Remove cooling fan ring Villiers Mk15
» Villiers Mk10
» villiers mk10
» Villiers Mk10
» Villiers Mk10
» villiers mk10
» Villiers Mk10
