Lister D air and lubrication
Post by anthony dibnah on Sun Oct 19 2014, 20:29
What is the best way to get the plastic part of the air intake on the carb to "seat" better to the brass? Is grinding paste useable? Or a good idea? Also,when greasing the rockers,what is the best sort of grease to use?
Last edited by anthony dibnah on Sun Oct 19 2014, 20:30; edited 1 time in total (Reason for editing : spelling mistakes)
anthony dibnah
I really need to post more
Re: Lister D air and lubrication
Post by blue cat on Mon Oct 20 2014, 18:00
There aren't any plastic parts in a Lister D carburettor, can you explain or photo what you mean.
I use a high melting point cheap grease for greasing the rockers.
blue cat  cat
Post by anthony dibnah on Fri Oct 24 2014, 17:44
hello Bluecat.I think its called the air valve....its under load by a spring,thanks for your help and input
anthony dibnah
Post by Locknut on Fri Oct 24 2014, 18:11
Hi,
I agree with Blue Cat - there aren't any plastic bits used in a Lister D carburetor.
The air valve consists of a metal valve, a weak thin metal spring,and an adjustable metal threaded tube that the valve moves up and down in - if yours has any plastic in it then it suggests that at some stage someone has 'bodged' it for some reason.
Hope that helps.
Kev.
Locknut
Post by blue cat on Fri Oct 24 2014, 19:39
The air valve does not need to seat particularly well. Make sure the brass plate has the chamfer on its upper surface next to the valve. That is all that is needed. The rest is down to the strength of the spring. When starting you hold the air valve against its seat to choke the carburettor. During running the air valve bounces between open and closed.
blue cat  cat
Post by anthony dibnah on Mon Oct 27 2014, 11:48
thanks bluecat
anthony dibnah
