Wolseley WD8 gasket question
Post by Engine widow on Sat Oct 25 2014, 15:07
Hi all, I am restoring a WD8 and have got it to the point where I could test it before the paint stripping begins. It has a new copper head gasket and the head bolts have been tightened as far as they will go but I have water leaking from the head. It has been suggested that I put a little sealer around both sides of the gasket, is this normal practise? If it is what sealer would be the best to use?
Many thanks
Julie
Engine widow
I really need to post more
Re: Wolseley WD8 gasket question
Post by billypurves on Sat Oct 25 2014, 17:23
Julie, A smear of Blue Hylomar on both sides should do the trick. Also, once you have the engine running and hot, tighten the head nuts down again. Billy.
billypurves
Post by Locknut on Sat Oct 25 2014, 19:09
Hi Julie,
I am a few miles down the road from you and have always found the guys at Motor Mart in Queen Street( between the war memorial and the station) to be very good - they should have Blue Hylomar if not they will get it for you,Trago Mills may also have it in their motoring section.Good luck.
Kev.
Locknut
