lister d starting problem
Hi,just bought lister d totaly in its working clothes got spark but the only way to get it to fire is to spray petrol into plug hole. I have already cleaned float chamber,the clip was broken on the top of the float that holds float,have replaced that.Any information on how adjust carb would be great.
welsh bob- Posts : 3
Re: lister d starting problem
try holding the little spring operated valve on the inlet down with your finger as you crank.... it will in create a choke effect an suck a richer mixture in.....also make sure you are using fresh petrol.. the modern rubbish even in the past couple of years I am now having problems with modern engines starting....
wdf- Expert
Hi.wdf thank you for your reply,cleaned carb and plug also cleaned points and there was some signs of life,I read somewhere about rubbing a pencil on tip of the plug did that after a few swings she fired into life,the engine was running fast so shut it down,adjusted the linkage to the governer it seem to be better,but needs further adjustment.Cheers Rob.
» Lister d starting problem
» r and H starting problem
» Starting problem Villiers MK10
» Lister d magneto problem
» Fuel problem on Lister D
