How to avoid looking a complete plonker.
Post by Woodsman on Thu Nov 06 2014, 14:47
When you have finished using steel wool to clean and polish all the bits you have taken off the engine, run a good magnet over the work bench BEFORE you start work on the magneto flywheel. Embarassed
Re: How to avoid looking a complete plonker.
Post by RustonMark on Thu Nov 06 2014, 17:31
What happened ?
RustonMark
Post by Woodsman on Fri Nov 07 2014, 08:37
Ended up with a 'hairy' flywheel - took ages to pick off all the little bits of steel wool.
Post by Villiers on Sat Nov 08 2014, 09:29
Hahahahahahaha!!! cheers
Post by tony RA on Sat Feb 07 2015, 22:29
Hi Paul
Your not the only plonker , Ive done the same thing But Ive done it twice . Sad Sad
We Will Learn
tony RA
Post by Woodsman on Sun Feb 08 2015, 16:15
Hi Tony,
Another piece of helpful advice - make sure the aerosol nozzle is pointing the right way before pressing.
Post by stationary stu on Sun Feb 15 2015, 16:19
Woodsman wrote:Hi Tony,
Another piece of helpful advice - may sure the aerosol nozzle is pointing the right way before pressing.
I can hold my hand up to that one, not funny at the time getting a face covered in red oxide.
Post by chiefy on Thu Apr 14 2016, 13:15
Just seen this its a right pain in the rear when you get a hairy magnet,i remember i had once been filing a piece of iron i later placed flywheel on the bench o dear it had more hair on it than the top of my head.Keith.
chiefy
Post by StewartH on Fri Apr 15 2016, 10:36
Been there - done that - and don't try putting it though the parts washer if its one of those tank washers - it just got more hairy.... looked like a flipping hippy...
StewartH
