Petter PC1
Petter PC1
Post by Dieseljohnyboy on Thu Dec 25 2014, 12:38
Hi Guys,
HAPPY CHRISTMAS to you all.
Just began a strip down of my new project the rather rare Petter PC1 diesel from around 1958, i have managed to get a few bits from Jim Perkins; he's a very helpful chap and has written a great bok on Petters Ltd. However just pulled out the piston and its in a terrible state; two big chunks missing where the two top rings go; amazing it was till running (and pretty well too) Anyone got a piston???? you never know might get lucky!!!!
Thanks,
Johny
Dieseljohnyboy
Re: Petter PC1
Post by kevjhnsn on Fri Dec 26 2014, 00:04
post a pic of the offending item and a idea of bore, depth, gougeon pin diameter and number of piston rings ect
all will aid in the search mate, also what engine was closest in size in that petter book at the time it came out in production as some parts may well be from the earlier or more popular one to it of the time
Re: Petter PC1
Post by Dieseljohnyboy on Fri Dec 26 2014, 00:47
Many thanks, i'll get a bit more info and photos, The PC1 engine has a 3 inch bore and stroke the same as a PAZ1, and both engines are the same CC. A PAZ1 piston may fit, but not sure, gudgeon pin and con rod may be different; i know the combution chamber on the piston crown is different, the pc1 has a central dished hole while the PAZ1 is offset, pc series engines were designed to run at upto 3000 rpm while PAZ1s were plodders.
pc1 conrod is No hc17. I know the PC1 is a very rare engine and chances of getting a piston is doubtfull, it may get too expensive if i go down the road of getting the piston repaired, which is a shame as it is an unsusual engine. Thanks, johny
Dieseljohnyboy
Re: Petter PC1
Post by Dieseljohnyboy on Fri Dec 26 2014, 00:57
Here is a picture of the piston out of my Petter PC1
cant seem to upload a picture, any ideas how to do it????
Cheers, Johny
Dieseljohnyboy
Re: Petter PC1
Post by Woodsman on Fri Dec 26 2014, 09:42
I had same problem with 'Host an image'.
Try creating yourself an account on Photobucket, load the images there then click the image to get the share links top right. Click the Direct link to copy the url to clipboard then use the Insert an image your post. Hope this helps.
Re: Petter PC1
Post by Dieseljohnyboy on Fri Dec 26 2014, 11:14
[img][/img]
here's the piston damage on the PC1 petter diesel
Dieseljohnyboy
Re: Petter PC1
