So what is it?
So what is it?
Post by steveanderson62 on Fri Dec 26 2014, 08:48
Recently liberated from the back of my fathers garage is the engine in the link below. With liberal oiling it now turns quite well, but with good compression. Petrol tank is missing, and the 'starting handle' bolt through the flywheel removed for safety. Struggling to get a spark but not had a good look at the mag yet.
No makers name or decals visible so far....
Thoughts???
steveanderson62
I really need to post more
Re: So what is it?
Post by kevjhnsn on Fri Dec 26 2014, 14:30
pic aint at the best angle to aid me ,a few at differing angles and close up of underside and gears always helps
guesing amanco or associated see your other post on this item
what s it?
Post by billypurves on Fri Dec 26 2014, 19:39
My guess would be a Lion.
billypurves
Re: So what is it?
Post by Bamfordlad on Sat Dec 27 2014, 19:53
My guess is a Lion, a couple of photos sent in to SEM will confirm what it is.
Bamfordlad
Re: So what is it?
