Lister D - Compression Loss
Post by Ally's_Engines on Tue Jan 06 2015, 17:50
I have a 1934 Lister D type. The old head gasket needed to be replaced, so I have placed a brand new copper one on. I did a test run and I can hear air hissing out of the holes where the push rods are. The head bolts are screwed tight and it can hold a full tank of water. Could anyone help me with this problem?
Thanks
Ally
Ally's_Engines
Re: Lister D - Compression Loss
Post by Matth92 on Tue Jan 06 2015, 17:54
that's allrite, that's just air out of the crankcase, those slots act as a breather, and I expect your leaking a bit of compression past the piston too, but wuldnt worry about it!
Post by Ally's_Engines on Tue Jan 06 2015, 22:36
That's very helpful, thanks. I think I'll check to see if the piston rings are free too.
Ally's_Engines
Post by billypurves on Wed Jan 07 2015, 20:44
Run your engine until it is hot, then retighten your head nuts.
billypurves
Post by Ally's_Engines on Thu Jan 08 2015, 10:11
I'll give that a go too, thanks!
Ally's_Engines
