Lister H80A Water Pump
Post by standard1200 on Wed Jan 07 2015, 21:31
Does anyone know much about this model of water pump as I cannot find that much using google. The pump was connected to a Lister D engine originally but is now missing the air chamber (i think that would be the correct name)?? Any information would be appreciated or someone to contact regarding spares or where I could get an air chamber from.
standard1200
Re: Lister H80A Water Pump
Post by blue cat on Fri Jan 09 2015, 13:37
This is actually a Lister H1 pump, you should be able to find much more about that out on the web.
Air chambers not available new (as far as I know) so a wanted ad on here, or regular ebay searches might find one (eventually).
Failing that you could attempt to make one using a suitable flange and a small gas cylinder.
blue cat  cat
Water Pump
Post by standard1200 on Sat Jan 10 2015, 07:58
Thanks for the information. Yes, I can find a lot more information on the H1. Do you know why the pump is stamped H80A if it's an H1.
standard1200
Post by blue cat on Sun Jan 11 2015, 19:50
It is not stamped H80A, that is the casting part number of the main pump body.
blue cat  cat
Post by allan grieve on Sun Feb 01 2015, 12:46
I have the part for the top of the H1 pump are you looking for one
allan grieve
